OK, I've seen my share of LCD monitors where only one of the lamp is gone.
Typically , the 4 lamp ones would have 2 lamps on top and 2 lamps on the bottom.
So, if only one of the 4 is gone, the inverter still shuts off the lamps to prevent damage to the inverter board's transformers (from what I've read).
There is over voltage protection and current sensing circuitry all built around the inverter IC.
I have sub in a good lamp for the bad lamp outside of the LCD panel and found the brightness is not significantly reduced. heck, even subbed out 2 lamps still make the monitor quite usable.
So my question is this. Is there a "simple" way to defeat the drive for one lamp or one set (i.e., 2 lamps) on the inverter board so it does not think there is bad lamp and shuts off all the light?
This way, I can rig up quite a few monitors as usable instead of going to recycling.
