Dell 1704 FPt Capacitors
  • CapacitorUser
    • Oct 2008
    • 11
    I should have posted this thread here.
    Here it is if someone wants to follow
    https://www.badcaps.net/forum/showthread.php?t=7645
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • FluxCap123
    Dell U2312HM Why are these capacitors different colors?
    by FluxCap123
    I have a Dell U2312HM monitor with a bad power regulator. As part of the repair I was going to replace the capacitors near the regulator. All 4 capacitors are the same size/voltage but two are brown and two are black (see attached photos). The reference numbers on the two different capacitors are: 1301(M) and 1321(M). Does anyone know what they mean? Can I use the same replacement capacitors for all four?
    Any advice would be appreciated. Thanks....
    12-06-2021, 08:48 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
