Dell 1704 FPt Capacitors
  • CapacitorUser
    • Oct 2008
    • 11
    I should have posted this thread here.
    Here it is if someone wants to follow
    https://www.badcaps.net/forum/showthread.php?t=7645
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
  • dell_sadness
    Dell Latitude 3440 - Service tag ending in 0001 - Locked!
    by dell_sadness
    BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
    Have extracted the BIN and want to know how to rebuild a clean BIOS
    I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
    I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
    Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
    11-12-2025, 02:54 PM
