Dell E228 WFP
  • Raji
    • Jul 2009
    • 6
    Dell E228 WFP
    So I just got a dell e228 wfp. upon turning on it lights up for a sec then goes off. I checked the CCFL's and they are good. I shined a light through the lcd and have picture. I tossed the power/ ccfl inverter board into the freezer and it stays on till it get hot
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Dell E228 WFP
    My theory : Bad caps that when hot have higher ESR than they normally have.
    Pics? Cap info?
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • dell_sadness
      Dell Latitude 3440 - Service tag ending in 0001 - Locked!
      by dell_sadness
      BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
      Have extracted the BIN and want to know how to rebuild a clean BIOS
      I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
      I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
      Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
      11-12-2025, 02:54 PM
