19" Westinghouse (simple fix? maybe?)
  • Horizonz
    • Jul 2009
    First Post! Yay! lol
    Been reading around here at the badcaps forums, and I'm finding these Westinghouse displays really don't like people. :P Anyway.. this Westinghouse isn't just a computer monitor (though it was used that way for 2 years), but an HDTV as well.
    When the screen died a couple weeks ago a did some research and found the solution here on Badcaps. Turns out it was a bad capacitor in the PSU. Being a novice to electronics (and that being my first attempt at fixing them), I was encouraged! ... Until another problem arose.
    An hour or so into using the screen after the fix I think something went wrong with the tuner. I was downstairs at the time when it happened.. when I left it was having trouble with softness (alotta pixelation in the screen), but it was displaying fairly decently. I figured it was the cable box giving a bad signal or something. I'd already ordered a new screen for my computer, so the 19" Westinghouse was simply being used as a TV now.
    When I went back upstairs, the colors on the screen and gone completely weird... everything was a gross shade of green or orange, there were bars of stuck pixels across the screen up to an inch thick, and the sound seemed distorted. The cable jack coming out of the TV was warm to the touch (I immediately unplugged the cable and power), and tapping/hitting the side of the screen would cause the bars to get unstuck, but create new bars of stuck pixels (all still in the gross shades of green and orange).
    I seem to remember seeing a video of the problem here on the Badcaps forums somewhere, but I couldn't find it. I turned here first because of my previous success with the PSU. I remembered reading something about a fuse here as well, but I don't know if that could be the problem or not... I don't even know if this can be repaired (especially by a novice like me ;]).
    I've taken pictures, but it seems my camera does NOT like close-proximity shots... so they're blurry. But they might help to give you a general idea of what I'm dealing with:
    Tuner Top: http://i42.tinypic.com/5d09xe.jpg
    Tuner Bottom: http://i40.tinypic.com/hsp8d1.jpg
    PSU Top: http://i40.tinypic.com/120l5rp.jpg
    PSU Bottom: http://i43.tinypic.com/14e84cx.jpg
    There's also some circuitry on the back of the LCD panel, but It's really long so I couldn't get a decent shot of it. I honestly doubt the problem would be there anyhow.
    So... any ideas? ^^;
  • EGuevarae
    • Nov 2008
    • 1336
    Re: 19" Westinghouse (simple fix? maybe?)
    First of all, welcome to Badcaps.net
    Your information is not complete.
    - No model for the LCD
    - Didn't tell what cap(s) was(were) replaced, and with what.
    - No brand/series/capacitance/V Rating for the remaining caps
    You might still have bad capacitors in there. What are the brand/series of the ones still on the board? If they are same brand/series of the one you changed, chances are they are failing (or will fail) too.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      I'm guessing the replaced cap is the nichicon in the bottom corner of the third pic.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
