HP X2301 LED Backlight Monitor Power/Startup Issues
+ More Options
Posts
  • DaemonCross
    • Jul 2018
    • 13
    • Philippines
    I have an OLD (7-8 years) HP x2301 LED Monitor that has been my workhorse for years. Just recently it's been exhibiting the FF:
    Issues.
    1. Powering On the monitor the day after use is a 50/50 chance if whether it works or not. The Power LED light lights up for 2-3 secs then turns off.
    Unplugging and replugging the device has a -small- chance to get it to turn on fully up to the point that it searches for a signal at that point the monitor is fully operational.
    2. The Monitor when fully activated is stable even when it enters standby/sleep mode it powers back up after you move the mouse. BUT when left extensively in sleep mode, after a few days or worse case a few hours the monitor shuts off.
    3. After opening up the Monitor, I noticed the Flatcable (FFC) leading to the LED backlight has slight burn/melted point. But the screen still seems to display fine, save for -very- subtle hints of green on one side. Refer to images.
    Repairs/Attempts I performed:
    1. I have already replaced the 2 through-hole caps with new ones. Issues remain
    2. Used a Different power brick with appropriate voltage. Issues Remain
    3. I've tried the blowdryer to heat the unit up before powering up. Monitor Succesfully powered up. I will need to retry this for a while b4 confirmation temperature affects monitor to startup. Preliminary Findings/Inconclusive
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: HP X2301 LED Backlight Monitor Power/Startup Issues
    You have a couple of voltage regulators with Vin, Adj & Vout pinout given. Have you checked the voltages.
    • DaemonCross
      • Jul 2018
      • 13
      • Philippines
      Hi, I'm a bit of a newb at this... haha. Willing to learn!
      So, how does one check these voltages and what should I expect? Whats frustrating about the monitors issue is that whenever I take it apart it powers up fine, haha. So it's hard to nail down what's wrong with it whenever you try something on it.
      Do you think it's not a capacitor issue? Since the thing is capable of powering up when it does?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        From what you have just said , that it powers up when opened up, I would think you have bad solder joints. Inspect all your solder joints and on all the connector solder joints and make good.
        • DaemonCross
          • Jul 2018
          • 13
          • Philippines
          Just opened it back up and... I managed to have it show symptoms while it's taken apart. Judging from what I can tell. The LED Power Light Flicked once then shut-off followed by very faint buzzing(s) with a pulse around the area in red in general. And The Light Blue ones are (from how i hear it) possibly what's emanating (or affected by) the buzz. As moving my ear over each one you can hear the increase in tone as you hover over them. The Buzz goes away (Normal Operation) after one or a few attempts of unplugging and re-plugging.
          I did notice that the Capacitor for the 5V (Higlighted in Green) shows 4.8v to 4.9v when in the buzzing + pulsing state. But when in normal operation it registers as 5.1v in both powered and standby. While the capacitor directly beside it is a steady 12v powered and standby.
          Image Reference Link: https://imgur.com/a/PvuKlae
          The (I assume) Power Regulators you mentioned.
          Model No. M482 G1084 (Highlighted in Pink)
          Standby Voltage - 1.2v (Both Legs)
          Full-On Voltage - 1.24v (Both Legs)
          Model No. 9997GH 11117H (Highlighted in Orange)
          Standby Voltage - 12v (Both Legs)
          Full-On Voltage - Right Leg - 12.32v
          - Left Leg - 8.54v
          I can provide you capacitor voltage readings (Standby/Full-On) if you want me to list them. But generally when in Full-On Status all capacitors "seems" to be generating appropriate voltages steadily (With LED Backlight). What do you think? Thanks!
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            This points to the issue being with startup capacitors.
            But as you mentioned you have an external power brick that should not be the case (startup cap will be in it)
            So as dick_barton mentioned it might be more likely to be a bad solder joint or hairline PCB crack.
            That said it wont hurt to replace those SMD electrlytic caps.
            As from your other thread the caps are 2x 100uF 16v and 1x 220uF 16v.
            But you should also understand that LOW ESR capacitors should be used.
            What where the original through hole caps in the monitor and what did you replace them with?
            • DaemonCross
              • Jul 2018
              • 13
              • Philippines
              Many thanks for the SMD Input, I badly needed that. It's crazy how the naming convention went south as far as SMD Caps goes. How hard is it to use v and uF right? haha.
              I reckon going a bit higher in volts cap wise should be the same thing as with through-holes? As long as I keep within the right uF values right?
              Uh... The caps that were originally there were...
              TAICON C1113(M) 25v 220uf Replaced with PANASONIC EEU-FM1E221 25v 220uF
              JAMICON 116C2(M) 100v 33uF Replaced with PANASONIC EEU-FC2A330 100v 33uF
              *Crossfingers, ESR is low enough, haha.
              So... What's that buzzing sound with a pulse I'm hearing? haha. I'm hoping that's just another symptom from a capacitor issue. Cuz all I have to work with is a regular soldering iron, I'm already iffy on how I'm gonna work those SMD caps, let alone those votlage regulators...
              By any chance can I use the Through Hole 220uF 25vPanasonics I got for the 220uf 16v SMDs? Assuming I can work it to fit, haha.
              Hopefully its not a hairline crack, haha. BTW Here's where I picked up the Hairdryer trick. Video Link -> https://www.youtube.com/watch?v=TXGxE9Fxhlw
              I was hoping its the same thing for my caps...
              • DaemonCross
                • Jul 2018
                • 13
                • Philippines
                Additional:
                It seems the voltages on the regulator indicated in pink increase in value from 1.2v (Both Legs) to 2.1v Left Leg and 4.7v Right Leg. After re-flowing some capacitor and diodes.
                Unfortunately Monitor still symptomatic. haha.
                  "Model No. 9997GH 11117H (Highlighted in Orange)
                  - Left Leg - 8.54v"
                  If you at the pin label: you see O (out), IN, and GND so GND pin should show 0V.
                  BTW, are those reading showing (-) number, I.E. - 12V, is that minus 12V or just 12V?
                  What is the DC output of that AC adapter, 12V?
                  "Model No. M482 G1084 (Highlighted in Pink)
                  Full-On Voltage - 1.24v (Both Legs)"
                  That is adjustable regulator: you have IN, OUT (MIDDLE PIN/BIG TAB), ADJ. So I do not understand your description as to what the 'Both Legs' means.
                  You can tell that it is Adjustable regulator because it has two resistor network on the ADJ pin and the Output pin and GND. We need to readings of all 3 pins. It is G1084 series 5A Adjustable regulator.
                  https://cdn.badcaps-static.com/pdfs/...644e76a444.pdf
                  https://cdn.badcaps-static.com/pdfs/...a1d22e7f22.pdf
                  The inductor with blue top and has '4R7' on top looks to be for Buck converter, its output feed the IN pin of that LDO regulator marked in Pink.
                  So at this point we need verification of the Voltage readings.
                  • DaemonCross
                    • Jul 2018
                    • 13
                    • Philippines
                    Hi!
                    I'm very new at this and just learning along the way (Self-Youtube), haha. So I'm lacking with the tech jargons atm. By legs I mean the long legs I skipped the unsoldered short ones in the middle.
                    The Voltages for the 9997GH is (-)12v on Both Legs on Standby. (-)8.5v on the Left and (-)12.32v on the right when live.
                    As for the M482 it is (+)1.2v on the left and (+)1.2v on the right
                    Yes the DC Adapter Brick is 12v.
                    The 4r7, Buck you mentioned. By Memory (Not 100% sure) I think (I don't have the monitor with me atm) reads 5v (I'm not sure if I tested this right, I just stuck the black lead to ground and the positive lead to the 4r7's inside leg beside the capacitor). And the Dual Diode thing beside it is 12v.
                    And by "Both legs". I just tested it with the Negative lead on the large tab (the metal lip on top). And placing the positive leads on the legs that are soldered to the board which is the left and right ones (Viewed from the top with Square on top of legs). The middle one appears to be unsoldered and cut/short I may be mistaken, haha. I guess I messed that up? How do I properly test these?
                    Yes I did notice, after randomly re-flowing some suspicious looking joints. The M482 voltage readings shot up to (+)2.1v (Left) and (+)4.7v (Right). (Monitor still symptomatic)
                    Here are some additional screens of the regulators from my phone. The middle legs looks like they aren't mounted for some reason.
                    Thanks!
                    • DaemonCross
                      • Jul 2018
                      • 13
                      • Philippines
                      Additional:
                      I did notice something peculiar. If you look at the image on the whole board. The IC's highlighted in blue on the far right, the bottom most one. When tested with a lead on the upper right leg in relation to the image.
                      Shows the voltage spike in tune with the pulsing in the buzz.
                      During Start-Up Failure it's spiking/pulsing 1.2v to 2.7v. When Monitor Functional/Powered On. It's 0v.
                      While the rest of the IC's highlighted in blue are a stable (+)4.7v.
                      Model No.
                      ATMLH110
                      02C M 6
                      0H2368K
                      The IC that's in tune with the pulsing is a different IC from those highlighted in blue.
                      I can't read the label clearly as someone left a silver ink blot on top of it. Partial read of it is...
                      Model No.
                      MXLC
                      ****2026E
                      ******-12G
                      • DaemonCross
                        • Jul 2018
                        • 13
                        • Philippines
                        Additional #2:
                        The D2 and D3 Diodes leading to the Regulator Highlighted in Pink. Not sure if it's related but if memory serves right.
                        D2 101F SM340A = 4.9v
                        D3 101F SM340A = 4.6v
                        I'm just curious why they seem to be in the same line but D3 seems to have lost voltage?
                          The reading should not be showing minus (-) readings unless you have your meter probe reverse or using the the wrong GND point.
                          Please look at the spec sheet I provide so you can make the correct measurement of ALL 3 pins of the regulators. The measurement of all 3 legs are ref. to CIRCUIT GND, same for ALL other Voltage measurement.
                          • DaemonCross
                            • Jul 2018
                            • 13
                            • Philippines
                            Alright! Will do!... When I get the time to go home I'll re-check them V's asap. Any other reading you need me to grab while I'm at it? Haha.
                            • DaemonCross
                              • Jul 2018
                              • 13
                              • Philippines
                              Ok, Update!
                              Sorry took a while, having a week of storm/hard rain (still ongoing) atm. Here are the readings of the 2 regulators.
                              I did 2 versions, One following this methodology. Link -> https://www.badcaps.net/forum/showthread.php?p=300999 (Option A)
                              And the other by placing the "Black/Com" lead on the GND labeled pin. (Option B)
                              Here are the results.
                              Option A. Black Lead/COM on Screw/PCB Mount
                              M482
                              G1084
                              Pin:
                              1 GND = (+) 2.12v
                              2 VO = (+) 3.37v
                              3 VI = (+) 4.62v
                              9997GH (Backlight FFC Cable connection with/without)
                              11117H
                              Pin:
                              1 GND = (+) 0v (w/out Backlight) | (+) 3.85v (w/Backlight)
                              2 IN = (+) 12.24v (w/out Backlight) | (+) 12.1v (w/Backlight)
                              3 O = (+) 0v (w/out Backlight) | (+) .1v (w/Backlight)
                              Option B: Black Lead/COM on GND
                              M482
                              G1084
                              Pin:
                              1 GND = Black Lead
                              2 VO = (+) 1.24v
                              3 VI = (+) 2.48v
                              11117H
                              Pin:
                              1 GND = Black Lead
                              2 IN = (+) 12v (On) (w/out Backlight) | (+) 8.24v (w/Backlight)
                              3 O = (+) 0v (On) (w/out Backlight) | (-) 3.7v (w/Backlight)
                              Now, Not sure why the 2 methods are giving me different results, haha (Forgive the Newbie). Sadly I couldn't induce the monitor to "fail to power-on" status. As the weather/temperature? does seem to matter of when it does fail. It's consistently powering up atm.
                                M482
                                G1084: This one is OK. 1.25V ref+ 2.12V on pin 1 = 3.37V
                                Pin:
                                1 GND = (+) 2.12v
                                2 VO = (+) 3.37v
                                3 VI = (+) 4.62v
                                11117H. This one is MOSFET AP9997GH, not regulator IC
                                Pin:
                                1) Please check the Voltage between point A and point when monitor is OFF and when you turn on the monitor, you will need to leave the probes on both legs while you are doing the test.
                                2) You need to check the Voltages on all 3 pin of the regulator IC U3 and TU5 as in option A.
                                • deleted
                                  • Feb 2022
                                  • 10
                                  • Philippines
                                  is this have a progress cause mine was working but after 1minute its getting off
                                  • mati mati
                                    • Jan 2025
                                    • France
                                    Hy. Have you please any idea aubout the IC circle in yellowโ€‹ ?
                                    • Jesus Coder
                                      Issues Reviving Old Dell 2408WFPb Monitor
                                      by Jesus Coder
                                      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                      06-25-2023, 02:33 PM
                                    • wattage
                                      AOC AG493UCX 49-inch monitor - Firmware request
                                      by wattage
                                      Hello Badcaps Community,
                                      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                      07-13-2025, 04:41 PM
                                    • Rick_1234
                                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                      by Rick_1234
                                      Good evening, gentlemen.
                                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                      Things I tried
                                      - Bought a new AC adapter thinking that was the problem but the problem...
                                      06-22-2024, 04:44 PM
                                      Wise Wing F199 19'' LCD monitor - recapped
                                      by momaka
                                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19โ€ CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                      When I saw the Craigslist post, I wasn't...
                                      08-24-2020, 10:58 AM
                                    • sew333
                                      Pc shutdown, monitor flickered with no signal after 10 seconds
                                      by sew333
                                      My pc:
                                      10850K stock 4800mhz stock Kraken X73 good temps
                                      2x16 GB DDR4 GSKILL 3000mhz XMP
                                      Seasonic Tx-850 Ultra Titanium
                                      Gigabyte Rtx 3090 Gaming OC
                                      Aorus Z490 Pro Gaming
                                      1 TB SSD
                                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                      Power...
                                      02-22-2022, 10:27 AM
