Need help how to read SMD caps...
  • DaemonCross
    • Jul 2018
    • 13
    • Philippines
    I'm very new to the electronics field. I'm attempting to repair an old monitor HP x2301 and I've already replaced the 2 Through Hole caps, and still no joy.
    With that I'm moving on to trying to replace SMD Caps, but I can't seem to read it right as the SMD caps have so much variance in how they are labeled. Where the V and the uF aren't indicated. And the layout between SMD manufacturers doesnt seem to follow one specific standard.
    Here are the SMD CAPS in question. I need Help Identifying/Reading the values so I can order the right replacements, haha.
    Note:
    The Through-hole caps are both new that I replaced. Monitor still symptomatic.
    Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
    by momaka
    I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
    For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
    https://www.badcaps.net/filedata/fetch?id=3591771
    https://www.badcaps.net/filedata/fetch?id=3591772
    It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
    https://www.badcaps.net/filedata/fetch?id=359177...
    03-12-2025, 03:42 PM
  • eryjus
    Heathkit IO-4205 Power Supply Caps
    by eryjus
    First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
    I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
    I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
    05-10-2023, 11:21 AM
  • Paxman_Swede
    Identifying caps on an old Zoom 9000
    by Paxman_Swede
    Hello!
    I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
    The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
    I have studied the board and...
    01-14-2025, 09:51 AM
  • captain150
    Help with switching power supply caps
    by captain150
    I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
    I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
