unfusing
  • ceramic
    • Feb 2009
    • 11
    unfusing
    What are dangers or problems you will encounter if you replace a fuse in an inverter board with a simple wire. Just wondering
  • PlainBill
    • Feb 2009
    • 7034
    Re: unfusing
    It depends on why the fuse blew. On rare occasions a fuse will blow because it felt like it. Sometimes it can fail due to a power surge, a leaky transistor, or possibly a bad CCFL.
    Let's say it was a shorted line to the CCFL and the protection circuit didn't shut down the inverter. You replace the fuse with a wire. The extra load on the transformer will cause it to overheat, the driver transistors will also overheat. Depending on design, you could burn a hole right through the circuit board, which will create a stink you wouldn't believe.
    I've got a low current (1/4) A variable power supply. Before I jumper across a fuse even temporarily I will hook that up and slowly increase the voltage looking for something going wrong. I have also been known to use an ammeter across the fuse location to monitor the current. When a circuit that blew a 2 A fuse draws 1 A for an hour or so I'm pretty confident it was just a momentary glitch.
    One example of just how bad this can get occurred at work about 30 years ago. The Boss (JW) went to use a piece of equipment. JW was a twiddler - he liked to take a pair of pliers and make sure everything was good and tight. On that day he did this on the power terminals to the test chamber. What he didn't know is the lug on the other side of the panel turned until it hit the chassis. When JW turned on the main power the short blew a 1A, 125V fuse. He couldn't find a 1A, so he replaced it with a 2A fuse. When that blew he tried a 20A 32V fuse. That blew too. But not before a pair of SCRs, the gate transformer, and the transformer driver transistors also blew.
    To compound the folly, this equipment was 20 years old, it was a special build by the manufacturer, and the manufacturer had been out of business for more than 10 years. It took a couple of weeks to dig out the schematic and identify the specs for the bad parts. The transistors and SCRs were easy - I picked up replacements as a local surplus store for $5. But the transformer was only available through the distributor. It cost $5, but the distributor had a minimum $100 order plus something like a minimum $20 shipping charge. By the time I got it working over a month had passed. Oh, and I hid his pliers, too, which really pissed JW off.
    PlainBill
    • Toasty
      • Jul 2007
      • 4171
      Re: unfusing
      You may experience any or all of the following:
      Total meltdown.
      Fire.
      A new odor in your room. i.e.- That "something electrical overheating" odor.
      Your smoke detector going off repeatedly.
      veritas odium parit
      • jpdoe
        • May 2007
        • 237
        Re: unfusing
        LOL
        Sticking it to the boss is always good
        • PlainBill
          • Feb 2009
          • 7034
          Re: unfusing
          LOL
          No!!! That's not where I put them (but I was tempted).
          PlainBill
          • Bobdee
            • Jun 2008
            • 461
            Re: unfusing
            Would these NO NOs still apply, if say you had a 1Amp SMD fuse that you bridged across the top say, with genuine 1Amp fuse wire, hypertheticaly of course.
            There is a thread somewhere on badcaps , that Lcdrepair sold a repaired inverter that the fuse was soldered blobbed
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: unfusing
              i like the new odor bit
              • Toasty
                • Jul 2007
                • 4171
                Re: unfusing
                @Bobdee:
                - "genuine 1Amp fuse wire" versus... counterfeit???
                - Since fuse wire reacts to heat, how do you solder it?
                - If it's an SMD and you can't get a replacement, try something such as Littlefuse's Picofuse line. They're about the size of a 1/8 watt resistor. IIRC Mouser & Digi-key carry them as well as the SMD's.
                @willawake: TY
                veritas odium parit
                • Bobdee
                  • Jun 2008
                  • 461
                  Re: unfusing
                  Hello Toasty
                  I seem to have some recollection in my head of seeing glass fuses that had blown, that were repaired outside with new fuse wire,soldered on end caps, many years ago mind you, but it might be my imagination, thanks for your info by the way.
                  bob
                  • Toasty
                    • Jul 2007
                    • 4171
                    Re: unfusing
                    Yes, you're correct. Years ago there were "Far East" ones that were done from the factory soldered too. I dug one from my parts drawer.
                    veritas odium parit
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Re: unfusing
                      I've seen them too, years ago when my father repaired CRT monitors ....
                      It was a common practice in Mexico to do that back then. Never did that myself, but I know first hand that it was done.
                      I also have bridged fuses (SMD ones) temporarily to test boards (did that with the Westinghouse I'm using now), and then replaced the fuse (sometimes). But I recall seeing many PSU/Inverter boards (even one in a recent thread, but I don't remember right now what thread was the one ....) silk screened as Fxxx or PFxxx, and having a jumper instead. I guess that overrides any security the fuses intended to provide, from factory
                      There are 10 kind of people in this world: those that understand binary, and those who don't.
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • 16gb GSKILL TridentZ RGB DDR4-3200
                      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                      • Windows 10 Pro x64
                      • GeForce GT1050
                        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: unfusing
                        As a temporary measure I've used a pigtail fuse, a fuse holder, or similar. If I have determined there doesn't appear to be an excessive current drain I have been known to use a single strand from stranded wire (for example, from a lamp cord). This allows me to do a burn-in for a few hours (hopefully one without smoke).
                        In any case, the goal is to wind up with something that an expert would look at and say 'neat repair', not 'what kind of a moron worked on this?'
                        PlainBill
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Re: unfusing
                          PlainBill
                          Yep. I use a fuse holder when possible, but with the SMD little ones I have bridged three or four.Now that I remember, I didn't remove the bridge on this very LCD...
                          • GeForce GT1050
                          • Toasty
                            • Jul 2007
                            • 4171
                            Re: unfusing
                            I prefer car jumper cables myself.
                            veritas odium parit
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              Re: unfusing
                              reminds me of the 1956 chevy sedan delivery i got free as a teenager.some moron sawed the heads off some 1/4" bolts and snapped them into the fuse block.luckyly nothing happened.
                              truck had a bad ignition switch.1 switch and a handfull of REAL fuses later and i had a nice truck.regret selling it.
                              • ceramic
                                • Feb 2009
                                • 11
                                Re: unfusing
                                thanks a lot guys. I've had to thrash a couple of lcd monitors because I couldn't find a replacement fuse. i was was tempted to just use a jumper but thought the fuse was there for a reason.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Re: unfusing
                                  OK, a couple of things here. First of all, NEVER trash an LCD monitor just because you can't find the proper fuse. PM me, If it's one I think I can fix I'll gladly pay shipping from anywhere in the USA.
                                  Next, for testing purposes you don't need an exact match on the fuse. There is nothing wrong with replacing a pico fuse with a pigtail fuse, or soldering in a fuse holder while you are testing.
                                  Last, if you are in the USA you can match just about any fuse made by looking in the Digi-Key and Mouser sites. I'm sure other countries have equivalent suppliers. (OK, if you're at McMurdo Station in June delivery might take more than three days.)
                                  PlainBill
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Re: unfusing
                                    PlainBill
                                    I can take them too. Just don't trash them. They can be fixed, used for parts or even the shell can be used.
                                    • GeForce GT1050
                                    • ceramic
                                      • Feb 2009
                                      • 11
                                      Re: unfusing
                                      PlainBill
                                      well, these are actually work lcd monitors and we usually send them to a recycling company when they aren't working. but i took the initiative to fix those that i can from my little experience and electrical engineering background.
                                      thanks for the info PlainBill. I tried soldering one of those SMT fuses, and it was a nightmare it was virtually impossible for me to solder without overheating or damaging it somehow. maybe i wasn't using the right equipments
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Re: unfusing
                                        SMT fuses are a little more tricky than snapping a new fuse into a fuse holder. It's pretty easy with a little practice.
                                        Remove the bad fuse, clean as much of the solder off the lands as possible. Drop the fuse in place and have something handy to hold it down. I suggest using a 25 watt iron with a small tip. Put a small drop of solder on the tip, hold the fuse in place, and apply the tip of the iron to the land until the solder flows onto the end of the fuse. Let the solder cool and repeat on the other end.
                                        As an alternative, use solder paste. Again, heat the land, not the fuse.
                                        PlainBill
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • nicktasios
                                          Macintosh Quadra 840AV PSU
                                          by nicktasios
                                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                          12-22-2024, 05:07 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
