ENVISION EN9410e 19" Monitor
  • Artoxx
    • Feb 2009
    • 4
    So, I am Monitor illiterate, it is the one area of a computer system that I have never played with, primarily because this is the first time I have had one that seemed to be worth saving that didn't already work just fine.
    Anyway, I got this monitor from a guy, as-is, and he told me some tech told him it was a $25 fix, but couldn't remember what the fix actually was. So I figured I would come here and see if it was identifiable by y'all without having to pay some tech a diagnostic fee as well as a repair fee. Maybe even fix it myself if it is a relatively simple repair.
    Problem: Plug monitor in, hook to computer, activate system. Turn monitor on.
    Monitor comes up big as life and holds for 3-5 seconds. Great pic. no visible issues. 5-ish seconds in, monitor goes dark, one sec later, comes back up, 1 sec later goes dark again. Runs in roughly 1 second pulses of on and off.
    Once it starts flashing, it continues doing so without variation up to the 5 minute mark which is all the time I gave it.
    Does this sound familiar to anyone?
    Can it actually be repaired for $25?
    Does this sound like the cost of just the part or the whole deal?
    Is this monitor really worth saving?
    And if so how much would the forum at large think was a good price to invest in it considering that I can get a 19" widescreen for $99 almost any day of the week.
    If you all know what this is, is it something that a monitor tyro should even think about fixing himself?
    I know how to use a soldering iron, and I have a multitester, but that is about the limit of my current equippage, is this something that can be fixed that easily, or am I most likely to fry it permanently?
    Hopefully I have given enough info for someone or one's to be able to help me.
    The main reason that I am interested in this particular monitor is that it has a square display as opposed to the widescreen format. My wife is kind of a freak and insists that she would rather have a 15" crt that takes up her whole desk than a widescreen lcd of ANY size.
    Not sure how I got such a freak. hehe
    Thanks in advance for your help.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: ENVISION EN9410e 19" Monitor
    I've seen them. They use an internal display. Haven't opened one yet, but that sounds like some V is oscillating, either in the inverter area or in the whole PSU. Open it up, and look for visible bad caps. Note the brand, capacitance and V rating, and post the info (with pics if possible, of the LCD's interior). It may be less than $25 if you already have soldering iron, flux, solder, or way to get/borrow them.
    And, Welcome to the forum.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • Artoxx
      • Feb 2009
      • 4
      SO, it turns out I am chicken. I removed the back cover of the monitor, and found that everything is concealed behind metal plates and aluminum tape of some variety, over the course of 30 minutes, I removed two strips of tape and three metal plates, only to find that there is another layer of metal brackets and clear plastic sheets taped and screwed into various places.
      I was unable to see any of the actual circuitry components as all the boards are installed comp. side down.
      This would mean dismantling EVERY seperate bracket and board section until and unless finding an obviously blown component.
      From what I can see, the circuitry is built on a much finer scale than any I have worked on for over 15 years. Therefore my confidence in being able to Find, IDENTIFY, and FIX the problem without screwing it up even worse, is NOT high.
      Therefore, I am rephrasing my question.
      Does this sound like a problem that can be fixed for $25. If not how much would be reasonable to expect to pay?
      Or am I wasting my time?
      I am going hunting/shooting next weekend, should I just it?
      • Wizard
        • Mar 2008
        • 2296
        we disassemble all the boards off the box and find a way to have boards flipped right side up for access with measuring tools. Under the boards i use cereal cardboard (boxboard).
        This is not only one happen to you, I had this many times and simply deal with it.
        Cheers, Wizard
        • EGuevarae
          • Nov 2008
          • 1336
          Cheers, Wizard
          That's true. I use an oversized mouse pad to lay the boards flat against the screen when I test them.
          Why don't you post a pic of where are you in the dismantle process and maybe we can suggest something. The repair almost for sure will involve replacing some caps, and they are not even close to $25 for good quality/reliable replacements most of the time (did a full recap of a 700P for less than $15 shipping included using Panasonic FCs from Digikey). You may pay the $25 and forget the issue, but you'll feel better when you do it by yourself. You are in the same situation I was two months ago, and I have opened and repaired quite a few so far.... and it is only a hobby, mostly.
          Come on, don't be afraid .... just post a pic and we'll point you in the right direction.
          • GeForce GT1050
          • Artoxx
            • Feb 2009
            • 4
            I told you I was chicken, I put it all back together already and stuck it back on the shelf.
            I am going to take it to one of our local tech joints and get a quote before I dive into it much further than I already did. If they can/will fix it for $25 I will let them. It will be less unpleasant than listening to my wife rag on me about destroying HER monitor. Even though I never told her I would give it to her even if it worked. I know how she is.
            Is that aluminum tape something that HAS to be there, or is it some kind of security indicator so the warranty guy knows if it has been messed with?
            I was not sure if it was to disperse static or what it was. If it is a necessity, I will have to get some before I dive back in.
            I have not messed with component level electronics for a VERY long time, I don't even know If I can tell a resistor from a diode any more.
            Any more suggestions will be appreciated, but I am not going to commit myself until I am sure that it won't matter either way. If It sits here broken it is not any use to me, if I cannot afford to HAVE it repaired, then it is of no use to me, and if all else fails and I try it myself and fail, well I have a nicel little target to test my new ammo on.
            On the other hand, if I try to fix it and succeed, then I will have learned something or other in the process.
            Thanks, if I decide to do it myself, I will post up with pics and stuff to get your advice. Looks like I am going to have to locate a decent magnifying glass as well, my eyes aren't what they used to be.
            • ChuckG
              • Mar 2009
              • 7
              I just got one of these in with the same symptoms--about 1-2 seconds between PSU shutdown and restart.
              When I looked at the PSU, this is what I found:
              Note the 5 bulging caps--4 in the right foreground and one in the background. They're all 470/25 CapXon units. I replaced them with Nichicons and the unit works fine.
              The odd thing is that the CapXons are on both the +12 and +5 sides of the PSU and failed nevertheless. I wonder if there's a plague of bad 470/25 CapXons out there?
              As far as the foil tape goes, my take is that it's mostly for EMI suppression for FCC Part 15. I left it off, but some aluminum duct tape (not the cloth type) would probably do the job just as well as the original.
              • EGuevarae
                • Nov 2008
                • 1336
                Yes, there's a plague. It ls called CapXon ....
                • GeForce GT1050
                • kc8adu
                  • Nov 2003
                  • 8829
                  • U.S.A!
                  ever notice that all the *.xon caps look as if they came from the same factory? also elite.maybe thats why they are always bad.
                  • Artoxx
                    • Feb 2009
                    • 4
                    Thanks Chuck, that is helpful. I am having trouble finding a local repair geek, the one that I was told about by the guy who gave me this monitor in the first place claims that they do NOT do repairs, they send them out, with a 6-8 week time frame between shipment and RESPONSE, never mind how long it will take them to finish the rotten thing.
                    I need to make a couple more phone calls, but it is looking more and more like I am going to have to do it myself or use it for target practice.
                    I will be in touch in that eventuality.
                    While I am thinking about it, what brand is both good and cheap, and where do I get them? The only store we have around here, that I am consciously aware of, that might have them is the Radio Shack, and that is just a MAYBE.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      The Shack carries only general purpose, non-low ESR caps only, and are very limited.
                      Order from DigiKey.com or Mouser.com.
                      Panasonic FC series are widely recommended. Just watch out the size of yours so you can match the size of the replacements. And stick with 105c temp rating.
                      • GeForce GT1050
                      • ChuckG
                        • Mar 2009
                        • 7
                        I'll ditto the remarks about Mouser or Digikey. You might find a deal on Everyone's Auction Site, but run the risk of getting counterfeits. Penny-wise, pound foolish.
                        Jameco or JDR are also known suppliers.
                        • ChuckG
                          • Mar 2009
                          • 7
                          This is not a difficult repair. Use a good-quality temperature-controlled iron (my 35+ year old Weller WTCP has been my mainstay) and either a solder "sucker" (e.g. Soldapullt) or solder removal copper braid. If your eyes are like mine (not as sharp as they once were), a head-band type magnifier (e.g. Optivisor) is useful for this and for reading fine print otherwise.
                          Pay attention to the capacitor polarity; work neatly and you'll be just fine.
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Any news on this?
                            • GeForce GT1050
                            • SuperHutt
                              • Aug 2009
                              I found this forum with Google when my son's EN9410e starting having a power problem. I opened the unit up as suggested and found the bad CapXon aluminum electrolytics on the PSU. I was lucky and located a big bag of Nichicon 470uF 25V caps on the long ignored parts shelf at my work place. After I wiped off all the layers of dust, I found the parts were in excellent condition.
                              I removed the bad caps and replaced with the Nichicons and now the monitor is functioning again! Thanks for the brilliant help with this issue.
                              I think it's time to search Ebay for bad EN9410e monitors that I can buy and fix.
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Welcome, and congratulations.
                                Not only EN9410e monitors are affected. I've seen many Envision units coming from eBay that have the same problems (not only Envision units, in fact).
                                • GeForce GT1050
                                • BigCanada
                                  • Aug 2009
                                  • 4
                                  Soooo....I have 3 Envision EN9410 monitors that all have the same problem. I have spent two nights (only a couple of hours total) taking it apart and looking stuff up as to what the problem may be. It is the same problem as listed here where the screen will show the picture and then turn off then show the picture, etc. I think it is the cap... wait for it... acitors!!!
                                  So I have included pictures to make sure this is what it is.
                                  I have not really delved into the world of hardware until recently when I switched out the RAM on my laptop, opened up the case on my VIAO, and bypassed the security system on my '94 Bonneville with resistors, so sorry for the noobishness. I was also wondering what is supposed to be connected to the pins that is surrounded with writing that looks like 1<->3 | 7.5mA, 1<->2 | 6.5mA, 2<->4 | 7mA in the top right corner of the board.
                                  Not the victory but the action; Not the goal but the game; In the deed the glory
                                  • BigCanada
                                    • Aug 2009
                                    • 4
                                    Sorry for the double post. Had to adjust images.
                                    BTW love this thread and forum! You guys are the most helpful I have found! Thank you so much from all of us who post and just read to get the information.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Whoah!!! Awesomely bad pictures, dude! The next time you do this try to get the entire board in focus.
                                      OK, to be serious now, the caps that are in focus in the angle shots all clearly have bulging tops. There are a couple that it's a little hard to tell. There are seven caps to replace; I've circled six in the attached picture, the arrow points to number 7. Replace them all, the extra expense will be minimal.
                                      Personally, I prefer Panasonic FC or FM series caps from Digikey. I just rebuilt one monitor; the total cost of the 11 caps was under $5.00. Since you appear to be in Canada, that should be about $3.75 Canadian
                                      If you desire help with selections, post the capacity, voltage, and dimensions of the seven caps I marked. Someone will note the proper replacements.
                                      The pins are used to set the over current limit for the CCFLs. The inverter controller monitors the current through the CCFLs and shuts down if any exceed the set point. Note that a jumper is glued in place. Moving the jumper is not recommended.
                                      PlainBill
                                      • Krankshaft
                                        • Jan 2007
                                        • 2328
                                        They just keep finding more ways to make things universal don't they?
                                        Probably the other jumper settings are for larger monitors with slightly larger CCFLs still smart though.
                                        I also like how the output voltages and currents are printed on the board if only more boards were this service friendly.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
