Asus VH242 white vertical line
  • FrankMtl
    • Sep 2015
    • 36
    Hi, I found this nice Asus monitor.
    It has a white vertical line (static line doesn't move)
    I attach 2 photos of the video board.
    It looks like a capacitor was change at some point.
    Could it be that the capacitor is failing again?
    Thanks.
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Asus VH242 white vertical line
    Vertical lines are usually a sign of the TFT panel going bad (or rather the ribbon cables attached to it are starting to get detached.)
    Post a picture of the problem, though, so we can evaluate if that's the case or not. Meanwhile, you could also try re-seating and cleaning the LVDS cable going between the logic and T-con board.
    • FrankMtl
      • Sep 2015
      • 36
      Hi, like I said in my post it's one single white vertical line.
      The line doesn't move.
      I already took a part the monitor I cannot take a picture right now.
      Thanks.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Probably a panel fault, as I mentioned. You can try moving the flat cables between the t-con board and the TFT screen right above the line to see if that makes it disappear or change colors. But apart from that, there's not much you can do with any simple tools. No parts to replace to fix that.
        • piernov
          • Jan 2016
          • 4435
          • France
          Sometimes you can find compatible panel on eBay in good shape for a decent price. I fixed my Acer X223HQ (vertical lines, 1/3 horizontal flickering) with an MT215DW01 panel found at $30 for example. Had to flash the firmware with one from an Acer X233H to get the OSD back (gray screen with the original firmware) and now the backlight control is reversed. Also I exchanged only the LCD panel (the translucent black panel) without the backlight assembly since it's a LED backlight and mine was originally CCFL.
          It's a lot of work but in the end the display is fixed and works perfectly fine (except for the reversed backlight control but that's not really an issue).
          • FrankMtl
            • Sep 2015
            • 36
            Thanks guys, I guess it will go to the recycling bin.
            Frank.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Well, you can put it on your local Craigslist, Kijiji, FreeCycle, or whatever you use over there (or simply put it outside your house with a "Free - broken" note on it). That way, someone may take it to use for parts. After all, the power supply, logic board, and CCFL tubes should be quite useful to someone who repairs monitors.
              • bdalkiran
                55EC930V white vertical line appeared (need help)
                by bdalkiran
                Dear All,
                I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                Please advice how to proceed and what is the...
                01-13-2023, 04:16 PM
              • lezsimply
                Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
                by lezsimply
                Hello Everyone and Good Day,
                I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
                11-22-2024, 03:14 AM
              • TrueSword88
                Kogan - KALED65XU9220STB - Blue Vertical Line
                by TrueSword88
                Hi all.
                I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                The line just happens to coincide with the end of COF and start of the next COF (attached).
                The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                Hoping to fix...
                05-05-2023, 04:28 PM
                ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                09-07-2024, 02:50 AM
                ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
