gateway fdp 1730 no power
  • hazim
    • Mar 2016
    • 62
    • egypt
    i have gateway fdp 1730 lcd
    no power put after several try plunged in power cabal monitor goes on and word good
    after shut down monitor and try powered again no power until i tried plunged and unplugged power cable 20 or more plunged and unplug til monitor power on
    i open monitor no caps bad power on big caps 310 volt
    i remove cable that go to inverter board
    and button cable no result
    no heat ics
    what can i do
    Re: gateway fdp 1730 no power
    Please up load good clear pictures of your boards so we can see what we are dealing with first.
    • hazim
      • Mar 2016
      • 62
      • egypt
      gateway 1730
        master hoarder
        • May 2008
        • 12175
        Probably the two small "startup" caps on the power supply board (next to the big 450V, 100 uF cap).
        Though I also see a coil/inductor on the logic board (the one with the Genesis chip), so you might want to recap that board too, just in case.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
        • mikey5791
          Philips 196V3L monitor power led off
          by mikey5791
          Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
          Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
          So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
          01-25-2024, 07:52 PM
