Nanao 9070S blinking LED and no picture
  • pentium
    • Mar 2006
    • 2778
    I'm building an 486 dream CAD system and because the card I am using has BNC outputs I needed a monitor with BNC inputs. This monitor was found at the university. It has the ability to switch between BNC VGA and TTL/non-TTL EGA, CGA and MDA. It was perfect.
    The problem is that I can't get a picture. I switch it on and all I get is a blinking green LED on the front.
    Visual inspection shows a yellowed spot on the back where the hot air from the power supply comes out and an internal inspection finds no instantly visible problems or faults. Could it just be dried out caps or what?
    Find Nedry!
    Check the Vending machines!!
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Nanao 9070S blinking LED and no picture
    Pictures? Brand/series of caps? Any noise with the blinking?
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • pentium
      • Mar 2006
      • 2778
      The caps are nippon chemicon.
      Also, I left the monitor plugged in and on for a while to heat stress it a little and after a while the led went solid and I got a picture. I switched it off and then on again and it instantly gave me a picture and if I left it off for a while I would have to wait again.
      Another problem that might be a little easier to fix is that the color is off in the lower left corner. I'll first move it and if it is still there I'll see if I can somehow degauss the thing.
      Find Nedry!
      • Wizard
        • Mar 2008
        • 2296
        definatly the bad capacitors that got bit better when warmed.
        Cheers, Wizard
        • EGuevarae
          • Nov 2008
          • 1336
          Cheers, Wizard
          Agree. I had a similar problem with a Proview that I had to "warm up" to work.
          Proview startup delay on cold problem
          It must be a bad cap (or caps).The monitor must be rather old ("EGA, CGA and MDA") so even if they are good brand, they might be dry.
          • GeForce GT1050
          • pentium
            • Mar 2006
            • 2778
            I'll have to look them all over some time. In the meantime I have to see what is screwing up the colors. It has to be somewhere on the swivel base as when I turn the screen left and right the colors change.
            EDIT: Actually, the monitor was made this month, twenty years ago.
            Find Nedry!
            • EGuevarae
              • Nov 2008
              • 1336
              Well, then your monitor is older than my sister.
              • GeForce GT1050
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                You want a free monitor with BNC inputs? I have a 1998 NEC multisync P750, 17", has BNC, D-sub, and a mac connector.
                • pentium
                  • Mar 2006
                  • 2778
                  Got no money for shipping right now. This will do for now and it fits in the timestream for the 486-era CAD/CAM box I'm building because I'm bored and have piles of old 486 parts and a copy of AutoCAD 12.
                  Find Nedry!
                    by momaka
                    03-15-2023, 10:17 PM
                  • Schwoin
                    Philips 243v5lhsb00 Monitor Picture too bright
                    by Schwoin
                    Hey everyone,
                    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                    you can see them on the top half of the photo.
                    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                    03-21-2023, 12:40 PM
                  • eurgenca
                    EGT monitor with bad picture. Help please.
                    by eurgenca
                    Hello.
                    I am struggling with EGT LED monitor. Panel is made from AUO.
                    I have 1/4 good and 3/4 bad pictures like you can see from the pic.
                    So far I checked power supply and it is ok. I cleaned connection from panel to LVDS and LVDS to digital board. No luck.
                    What is the problem with this LCD?
                    Pannel, LVDS or digital board. I have no idea so please help me someone.
                    Regards, Sebastijan....
                    07-26-2025, 06:10 AM
                  • matthewmcconaughey
                    I need help with my friend Sony GDM-FW900 24” CRT
                    by matthewmcconaughey
                    Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                    I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                    1. It started with a bright and greenish picture upon starting a cold monitor.
                    2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                    05-16-2023, 03:15 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
