HP L1925 LCD Video Input Logic Board won't accept signal
+ More Options
Posts
  • maverick530
    • Dec 2008
    • 107
    I have an HP L1925 LCD Video Input Logic Board that powers on, and I get the standard "check signal cable" display, but as soon as I plug in a source to either the DVI or Analog 15-Pin VGA, it immediately says "no signal" and places the monitor into standby. I've tried all different resolutions and cable types, but to no avail.
    What could be the cause of the board not accepting a signal? Could there be a blown capacitor somewhere? What else could I test?
  • EGuevarae
    • Nov 2008
    • 1336
    Re: HP L1925 LCD Video Input Logic Board won't accept signal
    I can only figure a TAICON from the picture. Can you give info on the other caps (cap, Voltage, brand)?
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      DVI and VGA are not hot-swap.
      Turn it off when attaching cables.
      Mann-Made Global Warming.
      - Dr Seuss
      • maverick530
        • Dec 2008
        • 107
        Once plugged in to inputs, I've tried cycling the power off and then on again, so that the cables are already plugged in, but as soon as this board detects a signal, it shuts down. I've never seen anything like it.
        • maverick530
          • Dec 2008
          • 107
          The smaller caps around the DVI/VGA inputs are black TEAPO 12/02 16v 10uF SS 105 degrees C.
          Slightly larger brown ones are: TAICON 16v 100uF 0304(M) 105 deg C (VT).
          There are also some larger 470uF TAICON, and the one big green one is TAICON as well.
          • maverick530
            • Dec 2008
            • 107
            I wonder if it's the TEAPOs that are the culprits since I have another of the same boards that is 100% TAICON caps (exhibits different problem).
            • EGuevarae
              • Nov 2008
              • 1336
              Teapo
              Replace the 470uf ones & test. Then if not working, the 100uf and then the smaller (10uf) ones.
              I've seen suggested the use of Panasonic FC series (Digikey) more than once around here. I ordered some of them, but in the meantime I've used Rubycons that I got from dead boards and so far so good....
              • GeForce GT1050
              • maverick530
                • Dec 2008
                • 107
                I finally got around to testing this board with a digital multimeter (DMM). On Ohm Resistence test (setting 2000), I saw that the following 4 capacitors (circled in attachments) registered shorted (0 value basically): 2 100uF and 2 10uF. *I tested them on-board*--haven't removed them yet.
                My question is, if I replace these 4, do you think it'll work? Do Caps normally go bad around each other like this? How sure can I be that it is the caps, and not some other component on the board?
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Have you tested the same caps on the other board?
                  • GeForce GT1050
                  • maverick530
                    • Dec 2008
                    • 107
                    Yes, I actually have 3 of these boards--all with varying problems. The other 2 check out fine on these same contacts. In other words, the others do not show a short for these caps.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Change them all. Teapos / Taicons give problems. You can start changing those at the signal input area, and then if it starts working properly, go ahead and change all the others now to prevent further problems.
                      • GeForce GT1050
                      • maverick530
                        • Dec 2008
                        • 107
                        Where's the best place to buy these caps online? What brand should I get? Thanks in advance,
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Panasonic FC series have been suggested more than once around here.
                          Reliable caps.
                          You can get them from Digikey.com
                          • GeForce GT1050
                          • maverick530
                            • Dec 2008
                            • 107
                            Ok, I just replaced the 4 suspected "bad" caps, and each circled tap still registers as shorted. I tested the "bad" caps once out, and they all seem to hold charges. So, it turns out that it wasn't a cap problem at all, and I'm still left with a bad monitor that won't accept a signal. What else can I try?
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • ohren
                              by ohren
                              09-08-2023, 05:24 PM
                            • Yanleb
                              LG 60PK550 Logic Control Board EBR63450301
                              by Yanleb
                              Hi all, I just want to share the repair of my 60PK550-UA TV set.
                              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                              C57: 3.30V
                              C61:...
                              07-20-2023, 12:38 AM
                            • korben_dallas
                              Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                              by korben_dallas
                              Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                              I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                              I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                              MY QUESTION:
                              I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                              02-14-2024, 12:23 AM
