Backlight issue with 19" v7
  • Weiner
    • Dec 2008
    Yes its a cheap walmart v7 lcd..
    No backlight upon powerup, a tap on the back of the power supply board behind the caps turns on the backlight and the unit runs fine. Ive checked for cold/bad solder joints, caps are 1000uf 25v Samxons. As un-scientific as it is could this be bad caps? or the tapping have nothing to do with bad caps..?
    trying to get an idea before i order caps i dont need..
    thanks
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Backlight issue with 19" v7
    Recheck. In fact, resolder/heat all the points with a soldering iron, as the knock seems to be symptom of a loose/cold solder point.
    Just my 2 cents...
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • Weiner
      • Dec 2008
      ok i'll go thru them again tonight, thanks
      • Cornito
        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
        by Cornito
        Hello Team,
        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
        08-08-2024, 08:09 AM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • Cornito
        TCL 65C715 backlight issue
        by Cornito
        Hello team,
        I'm back with another topic.
        It's a 65C715 TCL tv with backlight issue.
        But the problem is a bit strange.
        When I took this tv from the marketplace backlight didn't work but picture was ok.
        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
        Putting all back together the tv worked fine for weeks. => Contact issue??
        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
        06-09-2024, 02:24 AM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
        by momaka
        03-12-2025, 03:42 PM
