Viewsonic VP930 success
  • xpereta
    • Dec 2008
    I have just replaced the caps in my Viewsonic VP930 and now it works like a charm.
    The first symptoms where that the monitor would not start right away, I had to unplug it would power up after some attemps. After a couple of days it would seem to power but showed no picture, only the green led would blink slowly.
    I opened the case and saw a couple of swollen caps. You can see them on the left side in the attached image. It seems that these two where the bad ones or at least the worst offenders because the monitor worked fine after I replaced them. I decided to replace them all anyway.
    I must thank Pico for his post here: https://www.badcaps.net/forum/showthread.php?p=58843, thanks to his explanations I could purchase the caps on my way home because I had not written down their values.
    And thank you all for sharing your experiences! It seems that now our devices are built to last, as they should have been (well, to last a little longer anyway )
  • AntonChanz
    • Sep 2010
    Re: Viewsonic VP930 success
    I have the same monitor, same problem (no power but green blinking light, on opening up same 2 caps bulging (the 1000uf 16v ones)). Need to order replacement caps in the UK, but I'm getting confused as to whether the ones I have in my basket really are the ones recommended (the Panasonic FCs mentioned in the linked thread).
    The only caps that came up on a google.co.uk shopping search were these:
    http://uk.farnell.com/jsp/search/pro...sp?sku=1219463
    But they look like they are FM series not FC. Don't want to buy the wrong thing...
    Can anyone advise?
    • retiredcaps
      • Apr 2010
      • 9271
      Can anyone advise?
      Both series FM or FC will work fine as they are low ESR caps. In some respects, FM is superior than FC.
      --- begin sig file ---
      --- end sig file ---
      • uligli
        • Aug 2006
        • 139
        Congrat for the success! I recapped those 1000 uF 16v caps in January
        https://www.badcaps.net/forum/showthread.php?t=8841
        worked for 8 months, now i have some display's issues.
        https://www.badcaps.net/forum/showthread.php?t=10624
        • AntonChanz
          • Sep 2010
          Thanks, I'll order the FM then since its all I can find and they're dirt cheap anyway.
          • Dr.Nick
            • Feb 2013
            • 3
            • Sweden
            Hi everybody!!
            I have the same problem with my vp930 monitor.
            I´m a bit confused which capacitors a should buy.
            I have noticed that people on this forum talk a lot about "low ESR".
            What is a low ESR value and how important is this?
            A quick look at my local electronics shop website, and I seem to have four options.
            1. Panasonic EEUFR1C102
            1mF 16V
            8000h lifetime
            2A max ripple current
            Datasheet says "low esr same as FM series"
            This capacitor is listed as out of stock. They can order it for me,
            but I will have to wait a week for delivery.
            2. Rubycon ZLJ
            1mF 16v
            10000h lifetime
            ESR 0.038 Ω
            3. Rubycon ZLJ
            1mF 25V
            10000h lifetime
            2.5A max ripple current
            ESR 0.028 Ω
            4. Rubycon ZLH
            1mF 16V
            6000 - 10000h lifetime
            1.76A max ripple current
            ESR 0.028 Ω
            I do not know much about capacitors so any help would be appreciated.
            Regards
            Dr.Nick
            • selldoor
              Slow Learner
              • 7870
              Perhaps you should provide a link to your seller? so we can see.
              1mF is usually the same as 1uF but you need 1000uf?
              • Dr.Nick
                • Feb 2013
                • 3
                • Sweden
                Hello again, and thank you for quick reply.
                What I mean by 1mF is: 1milli F = 1000 micro F
                Link to seller.
                /Dr.Nick
                • selldoor
                  Slow Learner
                  • 7870
                  Hi OK- never seen a seller use mf so 1mf= 1000μF in which case any of the caps
                  you list would be good.
                  Is this one too long https://www.elfa.se/elfa3~se_en/elfa...9-53&toc=19089 is 8mmx20mm
                  • Dr.Nick
                    • Feb 2013
                    • 3
                    • Sweden
                    Hi selldoor.
                    The bad cap is 10mmx20mm wide so no problem there.
                    I should have mentioned that the pitch is 5mm.
                    Thanks a lot for your help.
                    /Dr.Nick
                    • MMartin
                      • Sep 2014
                      • Italia
                      Hi guys I'm new about this forum.
                      About the subject, I've 1 vp930 and 1 vp950?.
                      I suppose that they have the same problem, I'd like to try your suggestion about the caps. May I use your suggestion also for the VP950b?
                      Where I can find the list of the cap to replace and the mounting scheme?
                      Thank you in advance.
                      Max
                      • armst103
                        • Oct 2014
                        • usa
                        i replaced my caps .. the view sonic powers on now and i can change settings / my hp probook 6470b actually detects it as if its working but i get no display picture from the laptop when or any other pc. any suggestions?
                        • lostone
                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                          by lostone
                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                          05-19-2024, 11:40 AM
                        • StefanNg
                          Viewsonic VX2718-PC-mhd SG2701B01-8
                          by StefanNg
                          Hi, Badcaps.
                          I am troubleshooting a monitor
                          Viewsonic VX2718-PC-mhd.
                          Panel model SG2701BSG2701-8
                          Symptoms is no image.
                          This panel has 2 panel board connected by a U-ribbon.
                          When I disconnected the ribbon, I get a perfect half screen image.
                          I took some test point voltage, when ribbon disconnected.
                          HVAA 8.38v
                          FVDD12 1.21v
                          FDD33 3.3v
                          VIN 11.79v
                          VAA 16.85v
                          VGHF 30.16v
                          VGL -8.02v
                          CK1_I ~ CK8_I 1.403v
                          CK1_L ~ CK8_L 8.26v
                          When I connect both panel board
                          HVAA, VGHF, and CKx_L...
                          05-17-2025, 01:43 AM
                        • zomi
                          Manual cof bonding success rate ?/ feedback wanted
                          by zomi
                          Just wanted to get some feedback,
                          whats peoples' success rate with cof bonding repairs.....
                          09-23-2024, 12:45 PM
                        • valvashon
                          Repair Success! Middle Atlantic UPS2200R-IP
                          by valvashon
                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                          02-06-2024, 12:54 PM
                        • Valtekken
                          Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
                          by Valtekken
                          Specs:
                          • CPU=AMD Ryzen 5 3500U
                          • GPU=(integrated) Radeon Vega Mobile
                          • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
                          • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
                          Hello everyone.
                          My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
                          A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
                          09-10-2025, 04:14 PM
