Viewsonic 27" LCD turns off after a while -- longer on VGA, Shorter on HDMI?
  • capthook
    • Nov 2014
    • 25
    Ok, weird problem on my 27" Viewsonic ; model VX2753MH-LED. On HDMI, it works for about 4-5 minutes ; then resets to the viewsonic logo and does this over and over again. On VGA ; the display lasts much longer -- maybe an hour or more sometimes but then finally resets and does it frequently afterwords.
    I can post pics ; there is one PCB board inside of the unit ; the one which 19v 3A power supply unit is connected. And a PCB above it connected with a wide ribbon cable ; I guess that's the display attachment / backlight inverter assembly or something...
    1. Replaced all the caps on the video input board ; obviously just the large ones not the SMD caps and no difference.
    2. Tested the (external) power supply ; and it's steady at 19v. Tested the board itself ; to see if it was getting 19v after the plug ; and it seems to be fine.
    3. Tried running the display without the connector between the (backlight pcb?) and the video input board. Display turns on (white) ; does not turn off or reset ; so this does appear to be a problem with the input board.
    On the board there are two 330uH coils ; I was thinking about replacing those next. Any ideas? I'd love to have this big display back in action
  • capthook
    • Nov 2014
    • 25
    Re: Viewsonic 27" LCD turns off after a while -- longer on VGA, Shorter on HDMI?
    Here's a picture of the video input board I am talking about .
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      Can you detect any overheating in the logic board? (raster chip and linear regulator specially)
      • petehall347
        • Jan 2015
        • 4431
        • United Kingdom
        have you tried regular tv ?
        • capthook
          • Nov 2014
          • 25
          Unit doesn't have regular TV input... I did notice a chip heating up on the board ; really hot... almost too hot to leave your finger on. Yeah, don't think it's a linear regulator , those are (3 pins one side, one on the other?)
          • cpt.charlie
            • Sep 2013
            • 270
            • Spain
            Maybe the chip reaches a critical temperature and keeps resetting the monitor until you let it cool down.
            • capthook
              • Nov 2014
              • 25
              Thats what I am thinking.... I'll have to take the back off again and get the numbers off of the chip that's getting toasty...
              • capthook
                • Nov 2014
                • 25
                If input / output capacitors to that chip are fluctuating in value.. can that cause overheating as well? ... or is that not as common as just a bad chip?
                • cpt.charlie
                  • Sep 2013
                  • 270
                  • Spain
                  Are you talking about the SOT223 chip? linear regulators can oscillate under some circumstances (but seems to be uncommon)
                  • capthook
                    • Nov 2014
                    • 25
                    I don't think it's one of the SOT223's getting hot... it's a chip, I'll have to open it again and grab the numbers off it ; thanks mate.
                    • capthook
                      • Nov 2014
                      • 25
                      Ok the overheating chip is INL858RN...labeled IC501 on the pcb. Should i just r&r this guy and see what happens? It's the chip with 24 pins closest to the two 330uH coils on the pcb. Temp rises much faster on HDMI input, as opposed to VGA.
                      • capthook
                        • Nov 2014
                        • 25
                        Ok, I thought it was the IC.. but it could be the 330uH coil (inductor) next to it, lol. I got out the laser temp gun, and one of the coils is going up to 140 F , whilst the other next to it sits at a comfy 80 F... no fluctuation. I'm going to replace that first and see what happens
                        • capthook
                          • Nov 2014
                          • 25
                          Ok, I swapped the coils ; and the coil still gets hot in that position . ... maybe the mosfet 9997GH / regulator before the coil? ...
                          I can watch the coil / inductor in that position using a known good 330uH rise to temps above 140-150F , which is when the monitor shuts off. This was heating up components around it, which threw me off initially.
                          Please see the attached pic, i've highlighted both parts I am referring to.
                          • srhofmann
                            • Aug 2016
                            • 135
                            • usa
                            Perfect timing for this thread. I just put a new video card in a desktop and it's doing the exact same thing with the same Viewsonic monitor. The weird thing with mine is that if I use either hdmi input with a media player it doesn't seem to fail or at least I haven't seen it fail.
                            • capthook
                              • Nov 2014
                              • 25
                              Since you changed your video card - I wonder if your problem is related to the refresh rate ; did you change it to 60hz? tried multiple resolutions? ...
                              Mine does it with ALL devices... PS4 on HDMI, PC / Mac... doesn't seem to make any differece. It's definately hardware related on my end with this screen. The VGA input allows use for (hours) without problems. Use of HDMI inputs (either one doesn't seem to make a difference) heats up that 330uH coil really quick (saw it push 155 F last night) and then the display goes into a reset loop, or turns off. I'm going to dig into this further today... hopefully we can find a solution and not throw our huge 27" LCD monitors into the trash lol
                              • srhofmann
                                • Aug 2016
                                • 135
                                • usa
                                Turns out I lied. Made it fail using the PC and then immediately tried a media player and it does fail. Haven't tried the VGA input but I'll throw something on it and try it. It definitely seems to be heat related because it ran for almost an hour this morning before it failed and now it's resetting/rebooting every few minutes. I guess it's time to open it up and take a look.
                                • capthook
                                  • Nov 2014
                                  • 25
                                  Yeah, it sounds heat related like mine... on HDMI she'll last anywhere from 2 minutes - to under an hour. On the VGA input, much longer - sometimes almost 4, 5 hours or more without a problem. To be sure, I hit the same components with the heat gun to see if they were heating up as much on VGA ... they were, but it took much longer to get the heat numbers I was getting with HDMI hooked up.
                                  The 9997GH mosfet seems to be Ok, staying cool and also supplying a voltage of 3.3v for something else ; it's input voltage is 19.2v from the 2x 150uF caps on it's left. I didn't take it off the pcb to test, but it seems like it isn't shorting my meter or burned up. Also to note : the top 330uH coil (one closest to the 10uF 100v cap, which is laying horizontal on the pcb) is supplied with that 19.2v ; and the lower coil is running at just above 5v. The one supplied with 5v stays at around 80-88F, never really running upwards in heat. The top one just gets hotter, and hotter until finally it shuts down. You can put your finger on this while it's running and feel the heat coming off of it. It won't shock you.
                                  Also noted, the 100v 10uF laying horizontally is supplying 40v to the panel. I wondered at one point if the heat issue is normal on the coils ; but it doesn't seem likely to me because it gets really hot.
                                  • cpt.charlie
                                    • Sep 2013
                                    • 270
                                    • Spain
                                    I can't find any datasheet about the INL858RN is it some kind of led driver? what is the input voltage of the monitor? the chip could be a copy of the OZ9899.
                                    Check nearby diodes.
                                    • capthook
                                      • Nov 2014
                                      • 25
                                      Input voltage is 19v, 3.42A ... The inl858rn i believe is an LED inverter controller ic... it however doesn't seem to be heating up ; just the inductor... I noticed a russian and then another chinese supplier for the board, and that specific inductor had been replaced with a different 330uH inductor ..?.. But; logic says 95% of the time the inductor isn't the problem it's somewhere else; like to high of a voltage to the inductor itself. Plus I swapped them and the one that wasn't overheating in the other position started overheating in it's new position.
                                      We're talking 150 F , after a short period of time. Pretty hot.
                                      The top one that is getting hot is running @ 19.2 v, and the lower one around 5.2v... I'm wondering what controls the voltage to this top inductor... is it the mosfet above it? There is also a diode in line before that mosfet ... I feel like we're close ; wish I had some mosfets , the diode and the IC to just swap em out and see what happens, but because I have multiple displays I can wait and try to find the culprit with some guidance here...
                                      Should I check / watch pin voltages on the IC to make sure they are within range (see pic)
                                      Or should I investigate this overheating coil / inductor first? ... I'm thinking the later...
                                      The datasheet for this IC isn't complete ; but here's what I found : http://www.datasheetq.com/search.jsp?q=INL858RN
                                      • capthook
                                        • Nov 2014
                                        • 25
                                        correction ... I think these are 33uH ; thus a "330" inductor...
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • andrhouseolly
                                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                          by andrhouseolly
                                          Hi.
                                          I kindly ask you to help me solve the problem.
                                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                          The board turns on, there is no image.
                                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                                          When you press the power button, the button indicator lights up. The board works
                                          there is no image, there is no matrix initialization, there is no image on HDMI.
                                          When turned on, the fans do not spin, but when they warm up they start spinning.
                                          When you turn off the button, the fans spin up to full speed for a short...
                                          05-11-2024, 03:14 PM
                                        • Egidio85
                                          Samsung UE55F8000SZ Turns on and off immediately
                                          by Egidio85
                                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                          This defect happens continuously, hearing the classic click of the relay every time.
                                          Power supply board BN44-00636B
                                          disconnecting the mains and lamps from the power board always causes the same problem.
                                          Is it normal that without anything connected this power supply turns on and off cyclically?
                                          any suggestions on what to check?
                                          thanks in advance
                                          03-11-2025, 12:45 PM
                                        • mostachio
                                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                          by mostachio
                                          Hi Badcaps,
                                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                          TV Details:
                                          Model # - TH-65DX700Z
                                          Symptoms:
                                          The television turns on and displays a picture then makes a clicking sound and turns off.
                                          I haven't opened it up yet but...
                                          09-04-2024, 02:32 AM
