Samsung 2043NW Strange Issue with High Resolutions
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys I have a Samsung 2043NW LCD that is showing some strange problems. When I set the monitor to 1600x1200 it works just fine apart from the lower resolution. No flicker at all. When I switch the setting to the recommended 1680x1050 it has a black screen with some strange bars and slowly bleeds to being completely black.
    I know that the computer and cable are fine because when I plug another monitor in and set it to 1680x1050 it works beautifully. I looked at the power supply board and none of the caps are bulged.
    This is something I have never seen before. Any ideas on what would cause it to work fine in the resolution lower but not on the recommended resolution?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    Re: Samsung 2043NW Strange Issue with High Resolutions
    I would try replacing those 3 lytics caps on the main board.
    BTW, am I seeing brown stains on top of those lytics caps on the bottom right of the power supply board next to the white connector?.
      • 31259
      there are marks on ones without a vent, i think it's just marker pen.
      i'd change them anyway though.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Yeah it's just the marker they use at the factory. I'll change them and see what happens.
        canadaboy25
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          Tried replacing all of the caps and the problem is exactly the same. When trying to display a high resolution I can hear a faint screeching coming from the circuit board that travels along the top of the LCD.
          canadaboy25
          • Kjell
            Samsung Series 9 - BIOS issue
            by Kjell
            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
            08-01-2025, 09:15 AM
            09-07-2024, 05:50 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • vincentedel
            Samsung SyncMaster 740n Phase Control Issue
            by vincentedel
            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
            04-22-2025, 12:33 AM
          • Manucsl
            QE65Q800TATXXC Samsung TV Issue
            by Manucsl
            Hello.
            My TV is a QE65Q800TATXXC Samsung TV.
            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
            Any ideas to check would be very appreciated 😊
            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
            02-19-2025, 07:47 AM
