Dell LCD monitor
  • tarek.gharib
    • Oct 2008
    • 5
    Dell LCD monitor
    Hey.. I have a LCD monitor from dell, and it was blacking out. I opened it up and found the bad capacitor... The bad capacitor is 1000uf 16v. I was wondering if i could change that with a capactior that is 450uf 16v? Another question i have is how do i know which side is negative or postive? One side is shaded all gray, and one isnt? Thank you.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Dell LCD monitor
    You should never go lower in capacitance you can go slightly higher however I try to make sure that I never go higher than 20% (the tolerance of electrolytics).
    Anyhow you should replace ALL of the caps on the secondary side of the power supply not just one since the other caps will probably be ready to fail if are the same make.
    You need to use Low ESR 105 C replacements not just any General Purpose cap that most electronics stores carry.
    I recommend Panasonic FCs from Digikey or contact Topcat for your caps.
    As for which side is the negative side the one with the band running down is negative.
    Manufacturers usually put a bunch of - marks down this band which indicates the capacitors negative lead.
    • tarek.gharib
      • Oct 2008
      • 5
      Alright.. So i should change every single cap? Or just the ones that are like the broken one? And can you point me to a website that has thesse.. I have had trouble finding them in radioshack.
      • arneson
        • Sep 2005
        • 1267
        There's a lot of interest in the Dell and Viewsonic and Benq LCD failures.
        So when you meantion it please specify which model for everyones curiosity.
        Jim
        • tarek.gharib
          • Oct 2008
          • 5
          It is a Dell LCD E152-E153FPc...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Thank you.
            If you can tell us the brands of caps that are in it we can tell you which of those usually cause problems.
            All of whatever brand that bloated should go.
            After you know which should go and if you have time a list of the the problem caps such as: qty(of that cap), uF, volts, and diameter might be helpful to someone else reading this later on.
            Mann-Made Global Warming.
            - Dr Seuss
            • tarek.gharib
              • Oct 2008
              • 5
              Thank you guys very much.. Your fast replies are amazing. Well the "brand name" of the bulged capacitor is from Nichicon and there are 2 of them. They are both 1000uf 16v... So i guess i should change both of them right?
              • arneson
                • Sep 2005
                • 1267
                Since you replied so quickly, I checked on this one:
                http://cgi.ebay.com/DELL-E153FPc-FLA...d=p3286.c0.m14
                3 hrs at $32 is what I would pay just to get the glass.
                The shipping is what kills it.
                I've ended up with boxes of these things.
                Jim
                • tarek.gharib
                  • Oct 2008
                  • 5
                  Yeah. Im thinking of getting a new one if replacing the capacitors wont work. But i figured i could try and get a learning experience while im at it. This replacing of capacitors is interesting.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Nichicon is a good brand but they had a bad batch a few years ago are those caps on the inverter HM or HN series by any chance?
                    Those are the two series affected.
                    As for finding the caps PM Topcat or go to Digikey.com.
                    Low ESR caps made by Rubycon, Nippon Chemi-con, Panasonic, Samxon, or Nichicon to name a few will be fine.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      That's correct.
                      Nichicon HN and HM with date codes between 2001-2004 may be from bad batches.
                      Date code is as: [letter][2 digit year][2 digit week] and should be marked right on the caps.
                      HM and HN are different grades and you should consider the grade in choosing replacements.
                      So which series are they? (Even if they're not HN/HM.)
                      - Dr Seuss
                      • navratilova
                        • Nov 2008
                        Hi all, I need help in buying a Widescreen LCD Monitor for my new desktop? I am choosing between 2 monitors, both of them are in the same price range. Samsung 22" widescreen LCD contrast ratio of 1000:1. LG 22" widescreen LCD contrast ratio of 10000:1. The LG has a much bigger contrast ratio and I do not know what this means. I just want the best picture quality for my games and DVD watching. Thanks
                        I need a lcd monitor
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Samsung is known for crappy caps.
                          I have no idea about LG.
                          - Dr Seuss
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Yeah both of my Samsung LCDs had Crapxon caps in them I cracked them open and replaced them with Panasonic FCs.
                            They weren't bulging.... yet. But I like to take a proactive approach.
                            • Borse2008
                              by Borse2008
                              • There’s
                              07-15-2025, 04:55 AM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • DanPoka
                              by DanPoka
                              02-15-2025, 05:05 AM
                            • Jesus Coder
                              Issues Reviving Old Dell 2408WFPb Monitor
                              by Jesus Coder
                              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                              06-25-2023, 02:33 PM
                            • JarzabekPZ
                              DELL Latitude 5520 - charging only on one side of usb-c
                              by JarzabekPZ
                              DELL Latitude 5520
                              MB: South Peak 15 MB (DDR4)
                              Charging only on one side of usb-c on both ports. I have replaced one of the ports but still the same. Checked for short, nothing is getting hot under thermovision. Usb meter is not coming on one side, on the other is coming on and showing 20V.
                              Any sugesstions where to look for fault?
                              04-04-2025, 07:15 AM
