Syncmaster SA350 LED loses backlight - 2nd time seeing this monitor
  • axlmastr
    • Aug 2005
    • 158
    I had another thread here for this same monitor where I corrected a separate issue by replacing the IC401 on the board and uploading the firmware (red light of death).
    Now the same monitor is back for losing it's backlight. Green light is on. This progressively got worse over time to where it really just stays dark. Yes you can see the image using a flashlight. If the monitor is actually displaying and goes to sleep it never wakes up or so it seems. It's that the backlight never regains function. A poster on Youtube has this exact issue but his was the backlight connector on the panel. Mine doesn't seem to have this issue because I carefully split the panel housing and checked it.
    Can anyone point me in the right direction of where to start getting readings to determine which crappy IC it is this time? Thanks in advance. Pics are posted.
  • CapLeaker
    Leaking Member
    • 8081
    Re: Syncmaster SA350 LED loses backlight - 2nd time seeing this monitor
    Pics of the PSU, please?
    • 1supertech
      • Apr 2012
      • 384
      Did you check the fuse F901 first pic
      • axlmastr
        • Aug 2005
        • 158
        @Capleaker - This doesn't have a PSU board since it's power is integrated in the board pictured as evident by the low voltage connector in the bottom left of pic one. This has an external brick transformer as laptops do.
        I didn't say there was a problem with power as I could have easily checked that with an alternate power source. Ii powers on fine with a green light as it should. Sometimes displays. The backlight is out either shortly after power or within minutes.
        • axlmastr
          • Aug 2005
          • 158
          @1supertech - You are referring to the main fuse F901 next to the 12V power connector? Yes it's good because the unit powers on perfectly as stated in the initial post.
          This is not a dead monitor it is a working monitor with a backlight issue.
          My focus is more in the upper right of pic one where the circuitry related to the backlight cable leading out is or back over to the right edge where the signal circuitry is to possibly trigger backlight when the monitor sleeps.
          • 1supertech
            • Apr 2012
            • 384
            OK got it miss under stood so this is a new one on me I would check the caps with an ESR meter to if their failing or dead. just a thought.
              by momaka
              03-15-2023, 10:17 PM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              Yesterday, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
