Samsung 930b LCD cold start problem (inverter?)
Re: Samsung 930b LCD cold start problem (inverter?)
Some inverter board sections have a fuse and it could be open. Or it could be a shorted mosfet or transistor in the inverter section. These components could be on the backside as well and you will need a multimeter to test them.--- begin sig file ---
--- end sig file ---Comment
BTW, most members here including PlainBill would suggest changing all the capacitors except the largest one which rarely, but not never, fails.
Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.--- begin sig file ---
Re: Tech details on green fuse?
Can we get clear and focused picture of YOUR boards? Referencing other people's pictures doesn't help us diagnose YOUR problem. Your board could have unique characteristics not shown in someone else's photo like a charred resistor or suspicious looking transistor.
It is not uncommon for manufacturers to make changes on their boards. Also try to get the resolution as close to 2000x2000 as possible.
It would be a good idea to verify these, including the backlight on signal.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
Replace them all as a rule and you'll save time .....There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job)
Well, I'm no expert on electronics. I learn quickly but I was following this thread from the start and i replaced the caps. Others mentioned the fuse being problematic so I was looking for it to test it.
I did the whole power on and check with a flash light. I see the image so something is working right. I still will take some pics if I ever get some time.. been really busy fixing computers.
I think I found the fuse under a glob of rubber stuff. I'm going to check it out and see if its tests good. A friend of mine repairs defective Toyota ECM's so I might have an in on some help.. lolComment
Hi!
Problem is that backlights arent working at all.Power light is on. I replaced 3 bad CapXon 820uF 25v caps with 1000uF 35v and others 2x100uF16v,1x330uF 16v, 1x10uF 63v, 1x47uF 63v. I replaced them with new "JAMICON" caps. Replaced picofuse with litle wire.You can see picture but still no backlight. Where else to look?
Thanks!Comment
Hi!
Thanks!
Tip: You gave us good pictures of the top of the board. An equally good picture of the bottom would help us help you.
Tip 2: A fuse is placed in a circuit to protect components in case of an overload. Substituting a wire for a blown fuse without verifying the cause of the blown fuse has been eliminated often leads to more expensive and expensive repairs.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Measure the ON/OFF and A-DIM pins on the connector. ON/OFF should be about 3.3 volts, A-Dim will probably be lower, around one volt. If these are correct, trace the signals from the connector to the inverter controller. Check for proper voltages at the inverter.
PlainBill
My knowledge about electronic isn't too good but i measured it on the back of the board. On/OFF 0v, A-dim 0v, 5v and 13 are ok.
(i measured it without connected videoboard?)
Here are pics of the back.Last edited by rico_st; 06-09-2011, 11:18 PM.Comment
The A-Dim and On/Off are supplied by the video board,so you need to,have it connected to the PSU/Inverter,and then you need to arrange the Monitor to be switched on,with the VGA lead connected and your PC switched On.There are other ways but this is maybe the best way for you.When your Front panel lamp shows the PC signal has been recognised, then you should be able to measure the A-Dim and On/Off voltages.Comment
No problem, the Dim voltage varies depending on where the OSD level is set, BUT the on/off voltage should have turned the Lamps on, so plug them in....Comment
Well, looks like Last Chance Saloon,before the Backlights become the Main suspects,so I would resolder the Inverter transformers,and all other joints between the secondary and the Lamp sockets,eg the small Blue Caps etc etc.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
