Re: WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
From what I read, the d9200 does not have this...
btw, you shouldnt be asking advice while buying things.
it could turn out that you have been sold a frankenstein monitor assembled from fucked parts.
makes me wonder if the rest of the machine works - if i was you i would hook a pc monitor to the video socket on the end of the Naomi unit and change dipswitch1 to "off" to select VGA
The Machine works fine, just playing blind. I hooked up a monitor when I got it home, plays great. I really wasnt worried much if it did or not though, I will be stripping all the boards and GDrom out of it. The only thing I am leaving is the Monitor (if i can get it working), and the audio amp. (and of course lighting coin mech etc...) I am not sure what you mean by "I shouldn't be asking for advice while buying things?" I asked because I was not 100% sure. After talking to the tech he assured me that their are two assembly's for the d9200, but either will work with my tube. Just trying to figure it all out. My main interest here was in the excellent cab to modify. I only paid $120 U.S. , and am very happy with it. I was ready to drop in a LCD/LED monitor. If I get her working that will be a bonus. The working Sega Naomi Main board, GD-ROM, IOboard, PS, and audio amp etc Is well over worth more than I paid.....Last edited by proaudiosoft; 09-06-2016, 12:07 AM.Leave a comment:
makes me wonder if the rest of the machine works - if i was you i would hook a pc monitor to the video socket on the end of the Naomi unit and change dipswitch1 to "off" to select VGALeave a comment:
i just noticed something in your tube foto - where the hell is the convergence ring assembly?
did you strip it off or was it missing to begin with?Leave a comment:
you have no idea if that's where the problem is.
there is more than 50% chance that your neckboard is fine - and a good chance his is bad. (or he would be selling a complete chassis with tube)
that's not NOS anyway, it's a pull from a used monitor - fucker thinks we cant tell.
see the black sealant on the neckboard? that was to hold it on the tube!
and they did not cost that much new from WG last time i looked.
I ended up buying from a guy named Stan doing repair outta South Carolina. His listing is for repair, but he is sending me a whole new complete chassis, after the repair I am going to send him my old chassis.
Here is his listing: http://www.ebay.com/itm/WELLS-GARDNE.../331961558856?Leave a comment:
and they did not cost that much new from WG last time i looked.Last edited by stj; 09-05-2016, 02:56 AM.Leave a comment:
http://www.ebay.com/itm/27-CRT-Wells...3D331932555648
Curious, this guy is going to give me a pretty decent price, and the parts are NOSLeave a comment:
lets ignore the heating resistor for a while and try to get the neck heater working.
leave the resistor off he board,
re-assemble the thing and see if your getting heater voltage on the neck-socket pins when it's on.Leave a comment:
He says its for D9200 later model chassis that used flyback 053X0658001. The numbers on mine are 6174Z-6005G ....
It sure looks like one in the same though...Leave a comment:
I do not think this is cause of current issue, just years of heat focused in the area. When this problem is fixed I will tidy up and re-solder for good measure.Leave a comment:
Checked, All are about 390Ω.... Pins 6&7 on the tube is about 9.63MΩ. What about 3 and 6 @ 1.1 ohm, is that ok?Last edited by proaudiosoft; 09-03-2016, 02:13 PM.Leave a comment:
you should see a low resistance between 6 & 7 - that's the heater element!
and check the resistance between ground and pins 21, 24, & 26 on the 28pin chip
ground is on pins 11 & 22Leave a comment:
have you had a close look at the soldering at that point on the main board?Leave a comment:
can you show those pins on the neckboard foto?
i dont know how your numbering them.Leave a comment:
I tested all the components you asked, all tested good.Last edited by proaudiosoft; 09-03-2016, 11:19 AM.Leave a comment:
1-3 is the heater, so that's all good.
check q215, q220, d209 and sg204 < specially this.Leave a comment:
I checked. Any pins that show a reading together are in the Mega ohms, accept Pins 1 & 3 together, I get 1.1ohm. is this significant?Leave a comment:
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by SafrilhgHello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
How to determine the appropriate SMD resistor value for this condition? Thank You... -
by redbaron1007I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
