Samsung B1940 blue LED but blank screen
  • robcar
    • Nov 2015
    • 26
    • Italia
    I got this Samsung B1940 which got the following symptoms.
    When I connect to a pc and turn the video on the blue LED turns on firmly, but screen is blank, actually I should say the screen is white. Same problem with VGA and DVI port.
    If I wait let's say 5 minutes the video starts blinking, I guess because of standby.
    I opened it up and couldn't see any visible problems; I measured all the caps with an ESR meter and the majority are in the 0.0x ohms range.
    I measured the voltages on the secondary and they seem fine too.
    With power button of the video turned ON:
    B-Dim: 3.257V
    +13V: 12.71V
    GND: 0V
    GND: 0V
    GND: 0V
    +5.1V: 5.12V
    +5.1V: 5.11V
    N.C.: 0V
    O/F: 3.083V
    With power button of the video turned OFF:
    B-Dim: 3.261V
    +13V: 13.27V
    GND: 0V
    GND: 0V
    GND: 0V
    +5.1V: 5.12V
    +5.1V: 5.11V
    N.C.: 0V
    O/F: 0V
    I looked at the logic board and couldn't visually detect problems there, all SMDs which seem fine.
    Could someone please tell me what to check next?
    Thank you very much
    bye
    rob
    Re: Samsung B1940 blue LED but blank screen
    The Voltages and the signals are fine.
    Fuse F901 OK? It supplies B+ to run the Inverter circuit so it should have 13VDC at both ends with ref. to GND.
    • robcar
      • Nov 2015
      • 26
      • Italia
      Hi budm,
      I managed to measure both ends of F901: 13.31V
      So are you telling me that power board seems fine? Maybe I should look elsewhere? in the T-Con board maybe (never troubleshot such a board before)? The main symptom for this lcd is a white screen.
      • robcar
        • Nov 2015
        • 26
        • Italia
        One thing that I didn't mention is that this video has got integrated audio. So one thing that I can check is if sound at least comes out of it, so maybe I can rule out power supply issues. Let me try and I'll post the results.
        • robcar
          • Nov 2015
          • 26
          • Italia
          So, I wasn't able to hear audio, don't know if it was because I was missing something macroscopic...
          Anyway I attach other pics, one of the digital board and two of the T-Con.
          I was able to do measurements on the T-con contacts, just above the flat cable (I guess LVSD something ).
          Here they are:
          GND1: 0V
          RX00N:1.361V
          RX00P:1.130V
          RX01N:1.365V
          RX01P:1.132V
          RX02N:1.337V
          RX02P:1.150V
          RX0CN:1.259V
          RX0CP:1.289V
          RX03N:1.361V
          RX03P:1.127V
          RXE0N:1.363V
          RXE0P:1.139V
          RXEIN:1.364V
          RXEIN:1.136V
          RXE2N:1.344V
          RXE2P:1.162V
          RXECN:1.256V
          RXECP:1.289V
          RXE3N:1.358V
          RXE3P:1.132V
          GND2: 0V
          SDA_D:3.76V (cool: I2C bus )
          SCL_D:3.84V (i2c clock)
          WPN_D: 0.44V
          5V: 5.10V
          Now I have to go BUT it seems like F1 on the T-Con is broken! It is located just above the T-Con connector, on the right. So I'll have to check it further when I come back.
          • robcar
            • Nov 2015
            • 26
            • Italia
            So F1 on the t-con was blown. I managed to order a bunch of 3A SMD 0603 fuses, to desolder the blown one with ChipQuik and to solder one of the new teenie-tiny bastards.
            Then I made some measures; continuity was fine across it and also between the lead facing the flat cable of it and one of the legs of IC3 shown in the third pic.
            So I connected back everything again: nope, still white background, even if I got brief flashes of black. Disconnected cables, made measures: new fuse blown...
            • boyebaran
              • Sep 2015
              • 247
              • iran
              ic3 is a 3.3v regulator please check all pin in IC3 to GND.mybe IC3 damaged or IC4 and IC1 vcc shorted to gnd.
              • robcar
                • Nov 2015
                • 26
                • Italia
                Thanks for the tip; IC3 is fine, but CA16 is shorted. That one should be a cap.
                Now the question is: how can I tell its value? I guess I cannot...
                • boyebaran
                  • Sep 2015
                  • 247
                  • iran
                  first remove CA16 from board and testing .if you sure the cap is shorted
                  so you can remove the cap without replacing by new one.just remove cap and turn on monitor.be careful about removing CA16 .just remove by Soldering System and dont use hot air.
                  • Joe Black
                    eager to learn
                    • Sep 2015
                    • 173
                    • southeastern europe
                    Originally posted by boyebaran
                    first remove CA16 from board and test.
                    Indeed, you should try this. If you happen to have a schematics, you could confirm if CA16 is on the same rail as F1, so it could possibly short that rail to ground, blowing F1 as all that current rushes through.
                    Also, you could confirm if CA16 is actually a cap, (which most likely is), because it could be some other component which normally reads low on DMM.
                    Can you lower the brightness, or is the BL on max all the time?
                    stay classy
                    • robcar
                      • Nov 2015
                      • 26
                      • Italia
                      Thanks,
                      so it happens that CA16 wasn't itself shorted. After having removed it the pads underneath are shorted. And I figured out there are many more other caps that appear shorted to ground (sorry folks, I'm such a newbie and need to learn), namely: CA5, CB6, CB7, CB8. Then a pair on the left around the big chip. So it appears clear to me that there's a short somewhere, but where?
                      @boyebaran: hot air sucks, I have a station that just doesn't seem to work. I found
                      ChipQuik easy to use, even if bloody expensive.
                      @JoeBlack: I haven't looked for schematics yet and BL seems on max all the time
                      • boyebaran
                        • Sep 2015
                        • 247
                        • iran
                        seems that IC4 have problem.u need remove Ic4 to check.
                        one way to find short part .use power supply (1.5 V)with high current .connect (+ )to somewhere that short to gnd and( -) to gnd.
                        so turn on power supply(without turning on monitor) just a moment and see which part gone to hot.please be careful about this way.
                        • Joe Black
                          eager to learn
                          • Sep 2015
                          • 173
                          Are you positive that T-con blows new fuses?
                          Here's what I want you to understand: there may be short on the rail somewhere, and it blows your fuses and reads low on ohmmeter,
                          BUT
                          there may be one component along that rail which normally reads low on the ohmmeter and makes confusion.
                          You need to clarify how do you measure for short, using continuity on your meter, ohm setting or diode setting. That's why I'm writing this.
                          If you're positive on short, you can try what boyebaran suggested:
                          You could take desktop PSU or something similar and inject voltage to shorted rail. Voltage should be close to max voltage that rail is designed to withstand for best results.
                          Once you injected voltage, you feel with your hand for component which is the hottest, and that is your shorted component. However, for obvious reasons (too high V could kill many of your components), you have to know what are you doing before trying this.
                          Another, harder way would be to take sensitive ohmmeter and measure along the shorted rail. As you approach actual shorted component, the resistance will be slightly smaller and smaller. Patience required, ofcourse.
                          The actual reason why I brought BL up is that you haven't made clear if you have white screen as in white pixels or white screen as in screen to bright to see anything because of too strong backlight...
                          stay classy
                          • robcar
                            • Nov 2015
                            • 26
                            • Italia
                            I guess so. If I substitute fuse F1with a new one it just opens as soon as I turn the video on.
                            BUT
                            Ok.
                            I use continuity test.
                            He suggested that maybe IC4 is the culprit. It seems an FPGA, so no easy task.
                            Yeah, I got what you mean. Is it possible that t-con needs only 5V to operate? That's the line coming from the logic board.
                            Got it.
                            Backlight functioning really well, but no sign of image below.
                            So guys, thanks for all the help so far. I'm still uncertain if I want to further troubleshoot this sucker.
                            I guess that if I really want to fix it I could also look for a spare t-con on ebay.
                              It is not replaceable T-CON because you will need special equipment to do the tab bonding.
                              • Joe Black
                                eager to learn
                                • Sep 2015
                                • 173
                                Not good, your multimeter can beep on some low resistances that are not actually short circuits. For you, best way is to use ohm setting. However, if fuses are blowing, I'd call it a short to ground.
                                Totally understandable. With the situation nowadays, and the way things are going, you have to have really strong internal drive to tackle electronics repair, meaning that many repairs require more work and effort than someone who is not an expert is willing to provide versus paying someone to do it or just buying new stuff.
                                At this point, it all depends on how bad do you want it fixed and what's it worth to you.
                                stay classy
                                • robcar
                                  • Nov 2015
                                  • 26
                                  • Italia
                                  Got it; it's just that is so simple with continuity test not to have to look away from the circuit you're testing and just keep listening if the meter beeps. Maybe that's why people still use analogue meters when looking for shorts: with lateral view it's easier to see the needle going down.
                                  Not so badly, to be sincere. It was one my users' video, I gave him a 17" as a replacement in the meantime a batch of new 22" that we had ordered arrives
                                  Hey, nevertheless I really appreciated all the help from people that replied to my OP! I learn a lot from knowledgeable folks that post in this forum!
                                  I'll post updates if I manage to find the shorted component (maybe by using a thermo camera, hmmmm....)
                                  • Chrissygizmo
                                    by Chrissygizmo
                                    02-10-2025, 12:33 AM
                                  • gbbradshaw
                                    Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                                    by gbbradshaw
                                    Hi.
                                    I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                                    02-22-2023, 01:31 AM
                                  • mar1in
                                    Samsung TU8000, backlight and sound on, stuck in blue screen
                                    by mar1in
                                    I've got this Samsung here that would be stuck in a boot loop.
                                    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                    Thanks in advance
                                    11-08-2023, 05:43 PM
                                  • Chrissygizmo
                                    samsung galaxy ao2s very temperamental after screen replaced
                                    by Chrissygizmo
                                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                    Ive eventually managed to get it on and working but it's very temperamental...
                                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                    05-26-2024, 12:05 AM
                                  • Kiberge
                                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                                    by Kiberge
                                    HI guys!
                                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                    04-22-2024, 11:28 AM
