Asus VG248QE Power Failure ( E162032 Vol 3)
  • mobileunlockers
    • Jul 2016
    • 17
    Hi Everyone
    This is my 1st post in this forum. I have an Asus Monitor and having issue with the power. It comes on for 2 second then goes back off to stand by mode. I have tested all the capacitors on the power (E162032 Vol 3) board but still same issue. I have tested backlight and its fine as well. I have attached the picture of the power board, Can you please suggest anything? Thanks
    Re: Asus VG248QE Power Failure ( E162032 Vol 3)
    May I ask how you test the LED backlights? What DCV rereadings do you get at the LED connector?
    Pictures of the bottom side of the board?
    'It comes on for 2 second then goes back off to stand by mode.'
    BTW, do you have it hooked up to a running PC with Video signal?
    Does it go into standby mode if the LED connector is not in place?
    • mobileunlockers
      • Jul 2016
      • 17
      Thanks for a quick Reply.
      I have tested the backlight with Universal LCD tester for Laptop and all LED's Lights up fine. I have disconnected the LCD panel and Backlight but it still goes to stand by mode. When i press the power button it goes from red to Blue for 2sec then back to solid Red. I have also tried to plug into my PC but still no luck
        Pictures of the main logic board?
        Did you check any DCV from the power supply board feeding the main logic board and the Voltages on the main logic board?
        The power supply is an always on power supply so the DCV to the main board should always present.
        • mobileunlockers
          • Jul 2016
          • 17
          Yes i have tested all the DC Voltages from power board to the main board. I don’t know if they are the right voltages. (They seem to like really Low).
          From left to Right
          1 Brown 3.0v
          2 white 0.0v
          3 Black GND
          4 Black GND
          5 RED 5.0v
          6 RED 5.0V
          7 RED 5.0V
          8 RED 5.0V
          9 Purple 0.0v
          10 Green 0.0v
          11 Grey 0.0v
          All the voltages are present and stabled.
            I expect to see one more signal Voltage. Right now you have the 5V to run the main board, and I expect tow more low Voltage signals, one for the BL-ON and one for the Dimming so I will assume the 3V is is one of the two signal.
            The problem right now is to find out what the exact function for those pins to verify, at this point I suspect bad main board due to the fact that it goes into standby mode even the Video signal is present.
            • Rennokas
              • Apr 2013
              • 20
              • Estonia
              I have the same monitor and it shows constant purple light. No picture, but windows recognises the monitor. What does purple light mean?
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • gamartinelli
                Asus VG248QE won't power on / purple light
                by gamartinelli
                I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
                09-29-2022, 04:15 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • ShadowAi
                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                by ShadowAi
                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                03-15-2024, 10:46 AM
