Bad LCD ?
  • ddscentral
    • Mar 2008
    • 151
    • Lithuania, EU
    Bad LCD ?
    I've received a 19" monitor for free, IISonic Model IIW9M.
    The monitor turns on, but the video on screen is corrupted and it has a white stripe which dissappears and reappears sometimes when monitor is moved, but always remains visible in black background.
    Tried opening the monitor, nothing visibly wrong. Tried reconnecting the signal cable from lcd panel to the video board. Didn't help.
    All caps look ok. (but most caps are from the bad list: hermei, evercon fukkyu)
    What might be wrong with this monitor ? Maybe the LCD panel itself is bad ?
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Re: Bad LCD ?
    Hermei? Yuck.
    Evercon... GSC?! HELP!
    Fuhjyyu!? OMG even worse!
    Try replacing all the badcaps. Hermeis are prone to fail in LCD's and motherboards. Evercon and Fuhjyyu caps fail very often even in light-load spots.
    At first I thought it could be bad solder joints judging from the moving the LCD-thing. But replace the caps first.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Bad LCD ?
      caps are not causing this.
      its a connection issue.hopefully not in the lcd module.
      • ddscentral
        • Mar 2008
        • 151
        • Lithuania, EU
        Re: Bad LCD ?
        Yes, that was a connection issue.
        Tried slightly moving the connector from lcd to video board, the corruption is now gone, but that white stripe is still there, but only slightly visible in black background.
        But I wonder how long that lcd will last with all those crap caps onboard ?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Bad LCD ?
          try some deoxit on the connectors.
          if it clears then recap it.
            by momaka
            03-15-2023, 10:17 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
          • Rick_1234
            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
            by Rick_1234
            Good evening, gentlemen.
            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
            https://drive.google.com/file/d/1L6S...ew?usp=sharing
            Things I tried
            - Bought a new AC adapter thinking that was the problem but the problem...
            06-22-2024, 04:44 PM
            Wise Wing F199 19'' LCD monitor - recapped
            by momaka
            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
            When I saw the Craigslist post, I wasn't...
            08-24-2020, 10:58 AM
          • sew333
            Pc shutdown, monitor flickered with no signal after 10 seconds
            by sew333
            My pc:
            10850K stock 4800mhz stock Kraken X73 good temps
            2x16 GB DDR4 GSKILL 3000mhz XMP
            Seasonic Tx-850 Ultra Titanium
            Gigabyte Rtx 3090 Gaming OC
            Aorus Z490 Pro Gaming
            1 TB SSD
            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
            Power...
            02-22-2022, 10:27 AM
