I desoldered two fets and used the small screwdriver...pulled 3 solder pads off. what is the easiest and best way to fix. I am sure Kranksaft,DaveMax, or Kc8 has a solution for this. I am a novice at this. Just started two months ago. Have recapped three mobos and 1 lcd monitor. They are working fine. Any help would be appreciated. Will include pics soon. Need new bats for digital camera. Broke now cause went to casino in Biloxi, MS over July 4th. Thanks for any help
messed up on inverter board
Re: messed up on inverter board
If the pad is completely gone, then I sand off the track it was connected to - the thin 0.5mm edge of fine sandpaper folded on itself possibly to reveal the copper, then paint using ~99% conductive silver paint or a conductive ink pen connect it to the exposed track and paint a new pad, let it dry and repaint it if necessary a few times to make the new pad and track more conductive, check that the track and pad are conductive. The new pad and track made of thin silver paint will be weak, but if you're careful you might get one soldering out of it without breaking it. As your new pad is made of silver you may want to use silver bearing solder to ensure a good joint.
I've given this advice on other forums and following it others have succefully repaired their equipment. But I can't make any guarantee's, it's just something I thought of that worked rather than a known repair techinique.Rubycon Rubycon Rubycon
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
