Samsung Syncmaster T240 - dim screen
  • atomc
    • May 2016
    • 9
    • España
    Some time ago, my Samsung Syncmaster T240 suddenly lost the screen brightness. After opening it, I saw that the TM-09175 inverter transformer is damaged (melted on top).
    Actually the monitor is working, but adjusting the brightness at 100%, the screen looks a bit dark and seems as if it was set at 40% brightness.
    I ordered today the inverter transformer and I hope to receive it in three weeks. Meanwhile, I can do some testing if anyone believes that there may be some other broken component.
    Thanks in advance.
  • 1supertech
    • Apr 2012
    • 384
    Re: Samsung Syncmaster T240 - dim screen
    Test resistor R301 looks like it got a bit warm
      I would recap the board.
      You can also have worn out lamp so it draws too much current as caused one of the two high Voltage windings to burn out.
      • atomc
        • May 2016
        • 9
        • España
        Unsoldered R301 = 390K
        You can not distinguish the colors of the resistor, but I've seen pictures of the same power supply and seems the correct value.
        If I have a worn out lamp, can I do something?, worth it?
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • unimatrix93
          Replacement transformer for Samsung fridge
          by unimatrix93
          Dear forum
          My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
          No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
          The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
          My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
          07-14-2025, 02:16 AM
