Commodore 1084s p1 monitor went black
  • Amiga64
    • Apr 2016
    • 10
    • germany
    Manufacturing date 1990.
    Had not been used in 5 years, and worked fine for 10 minutes.
    Then screen went black with a fading white horizontal line in the middle and it started buzzing...
    Now just a black screen and buzzing when you turn it on.
    Does this sound complicated or expensive to fix?
    I had the monitor repaired 20 years ago, back then it was already difficult to find a shop that could do it, I called a couple again but they don't want to deal with those old monitors.
    I can't find any leaking, or bulging capacitors, but maybe one of the experienced folks can spot something?
    http://postimg.org/image/9bijkz2on/
    http://postimg.org/image/ku4pbhc2f/
    http://postimg.org/image/rqq5fwajb/
    http://postimg.org/image/95tnk387r/
    http://postimg.org/image/rdmcqm2xj/
    http://postimg.org/image/mt9tmjexj/
    http://postimg.org/image/oy7ysukpj/
    http://postimg.org/image/tr9sy44lz/
    http://postimg.org/image/68ljg4rpz/
    http://postimg.org/image/5dpt2m53r/
    • 30983
    Re: Commodore 1084s p1 monitor went black
    vertical deflection failure,
    post REAL pictures and not thumbnail previews!
    what input connector is it, scart, din or 9pin-D ?
    • Amiga64
      • Apr 2016
      • 10
      • germany
      It's a 9 pin d sub connector
      What needs to be fixed for a vertical deflection failure?
      They are real pictures but the don't come up when you click... I will fix that
      • Amiga64
        • Apr 2016
        • 10
        • germany
        I can't get them to work as clickable thumbnails...
          • 30983
          click "go advanced"
          then click "manage attachements"
          then upload the foto's
            • 30983
            this will be handy
            • Amiga64
              • Apr 2016
              • 10
              • germany
              Thanks, but it does not say anything about diagnosis.
              I have been told it is useless to try it as Commodore has been bankrupt for over 20 years, and there are no parts available.
              But I gather the majority of those resistors, capacitors and such are still universal.
              Here are the photo's as attachment:
                • 30983
                that's bullshit because it's a rebadged philips CM8833 MK2
                i will look at the pdf later, but put simply, you need to locate the vertical deflection chip, check the solder joints, and replace any small caps related to it.
                as a starting point anyway - it may have a blown chip - but it's unlikely.
                you find it by finding the scancoils on the schematic and then following the vertical drive signals back to the source.
                  • 30983
                  btw - i own one.
                  • Amiga64
                    • Apr 2016
                    • 10
                    • germany
                    Does Phillips still have parts available for those old monitors?
                    BTW I checked the bottom side of the board for broken solder joints and such, but everything seemed fine.
                    Was it a lucky strike that I saw how it went out? All it does now is have a black screen and a buzzing noise.
                      • 30983
                      you should not keep testing it, you can cause more damage.
                      can you read the part numbers on the large chips fitted to heatsinks please.
                      • Amiga64
                        • Apr 2016
                        • 10
                        • germany
                        You mean the shield on pic #7?
                        3138 198 63790
                        103142873
                        The only chip with a heatsink I can find is in the bottom right corner of the last pic...
                        But the heatsink is either glued to the chip or soldered to the board...
                        The numbers right below it are
                        3138103 31854
                        3138103 31844
                        • Porto
                          • May 2015
                          • 109
                          • NL
                          Nice monitor, own one too, together with an Amiga 2000.
                          • Amiga64
                            • Apr 2016
                            • 10
                            • germany
                            There is no glow in the neck when I turn it on. Could it be a problem with the power supply?
