Dell 2405FPW blown transformer?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Asxetos21
    Dell Latitude 5511 audible electrical noise
    by Asxetos21
    I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
    The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
    Any advise on how to narrow it down?
    The schematic is available here:
    Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
    03-03-2025, 09:53 AM
  • Reintar
    Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
    by Reintar
    First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
    One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
    08-30-2024, 06:13 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • Dynamite76
    Dell D635EF DELTA DPS-635AB PSU with blown TNY280PN
    by Dynamite76
    Recently I got a DELL PSU from a presision T3600. It is a 635W PSU which went out with a bang and some black smoke. The model of the PSU is a D635EF made by DELTA.
    The cause of the bang was a blown. TNY280PN Chip. How ever as a result or as a causo also two SMD resistors are smoked. I have been able to replace the TNY280 Chip but I do not know the values of the resistors. The resistors are within the Drain line of the TNY. I can not find the schematic of this PSU. THe resistor are Open Loop and on the voltage accross them is about 330V. (EU)
    Any suggestions for...
    07-27-2023, 01:52 PM
