Transformer for HP zr24w
  • DENis_S
    • Sep 2017
    • 5
    • Russia
    Re: Transformer for HP zr24w
    Originally posted by douardda
    A TNY279 only cost a dollar or 2, so just replace it and you'll see if it is indeed the cause of your failure (I also bet it is).
    Yes, it was it. All works fine after replacing of TNY279.
    Thank U gratefully. U really helped me to save ZR24w. Your story of repair was the only that I had found.
    Is that a common problem fo PSUs? I have the old TFT-TV with the same problem.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Good to hear you got it working.
      No, usually those offline SMPS ICs are not a common problem. Most of the time it's the caps that go bad in LCD monitors, followed by the occasional rectifier... and of course, backlight issues (bad CCFLs, inverter transformers, inverter transistors, etc.). The offline SMPS ICs rarely go, but I suppose there could be some specific PSU models that have these particular issues. Now that there are two of you who encountered this particular issue with this monitor, it is quite possible many other zr24w monitors are like that.
      • raph
        • Apr 2018
        Hi all. I just repaired my defective HP ZR24w by replacing the TNY279. Seems quite common with these displays. In my case, the TNY279 had actually exploded, ripping of the top part. Thank you for describing problem and solution so well.
        • cuctimthanchet
          • Apr 2020
          • Việt Nam
          hp zr 24w
          exploded
          • Paxancz
            • Aug 2020
            • Czech Republic
            Please help,
            i my case... TNY dead and rezistor R961 same and I dont know value or type ("burn"). Thanks for reply.
              Originally posted by Paxancz
              Please help,
              Show us the pictures of YOUR whole board, and the pictures of this R961 location.
              • balobi
                • Jan 2015
                • 88
                • phillippines
                #27
                Originally posted by johnatan
                can you please send me marking of IC I907?
                thnx
                i have the same issue with johnatan. blown IC 1907. what part number is that? thanks!
                • lotas
                  • Jan 2016
                  • 4882
                  • Russia
                  #28
                  Originally posted by balobi
                  i have the same issue with johnatan. Blown ic 1907. What part number is that? Thanks!
                  ic 1907 - tny279pn
                  • Arokiaraj
                    • Aug 2021
                    • India
                    #29
                    Do you have schematics of this
                    • Arokiaraj
                      • Aug 2021
                      • India
                      #30
                      I would appreciate if a schematic for this psu would be uploaded
                      • lotas
                        • Jan 2016
                        • 4882
                        • Russia
                        #31
                        https://whatever.sdfa3.org/hp-zr24w-psu-repair.html
                        • wil92
                          • Sep 2022
                          Originally posted by gunnish
                          I measured the power supply, 5V is ok, but 12 V and 19 V reads 0 V, just plain dead.
                          So i measured the caps and diodes, they are fine. So then I looked at one of the transformers, the resistance between the conductors on the secondary is 0.2 ohm, so short circuit.
                          How do I find a replacement transformer, I really don't understand the markings.
                          I know this is an old post, but I'm looking for the schematics of the zr24w power supply, if someone can help me it will be very appreciated.
                          • Hydargos
                            • Jul 2025
                            • France
                            #33
                            I spent a long long time looking for such schematics but was not able to find one.
                            For my problem, the post from douardda made my day.
                            BR
                            • learnmore
                              Help choosing replacement transformer for Levoit 600S SMPS
                              by learnmore
                              Hello Community,
                              I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                              Peace
                              LM...
                              11-04-2025, 09:35 AM
                            • mikey5791
                              Is it possible for transformer substitution?
                              by mikey5791
                              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                              My questions are
                              1. How do i test to see if the transformer is in good working condition?
                              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                              Hope you guys understand what i was asking. My intention is...
                              11-03-2022, 02:11 AM
                              ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 04:40 PM
                              ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 12:00 PM
                              ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 11:50 AM
