Samsung NP300E5A display vertical lines
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    Hello! I have a Samsung NP300E5A with an LCD display of 15.6" (LTN156AT19-001) where all of a sudden vertical lines appeared. External video displays work correctly, both DVI and HDMI. Is there any way to determine whether the issue is in the video cable or the panel itself? Cost of the panel is so high that it is not viable to change it. The cable on the other hand is very cheap. I took the screen off of the frame to try to flex the cable while it is on, but moving cable doesn't give any effect. Also the lines are always the same, not less, not more.
    Thank you for any help!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung NP300E5A display vertical lines
    Unlikely to be cable, sorry, it looks very much like tab bond failure on the screen to me.
    Sometimes you can get lucky and apply a bit of pressure in the right place and it will disappear. Be careful though.
    • Iersuo
      • Oct 2015
      • 31
      • Ulu
      It was indeed the screen, got it replaced, now perfect
      • diif
        • Feb 2014
        • 6978
        • England
        Great stuff thanks for the feedback.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Good work, its the address driver packs that are responsible for addressing the rows pixels. Each row has two transistors in the Ic, looks like a few of the transistors for the green sub-pixel rows inside the Ic shorted and caused them rows to be stuck open and you get stuck lines.
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • arctor
            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
            by arctor
            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
            04-26-2025, 05:22 AM
          • rfxcasey
            Vertical Lines on Half of LCD Display
            by rfxcasey
            I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
            05-16-2024, 06:52 AM
            Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
            This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...
            09-06-2024, 10:20 PM
