benq fp767 backlight
  • tattoum
    • Apr 2008
    hi to all
    i have a benq fp767 monitor that when i turn it on it works perfectly for 1 or 2 seconds then it becomes black and after some seconds it flashes for a 1 seccond then black again, and every timer i turn the monitor off then on it does the same thing. the green led is on and i can see the picture so its a backlight problem, i test the 4 c5707 and the 2fu9024n they are all ok. now i dont know what to do and what to check else please help me to repair it.
    thanks to all helpers
  • claybv
    • Mar 2008
    • 8
    Re: benq fp767 backlight
    Check Your caps ,usually about 4 to 8 caps may need to be replace. cant give exact detail on your model but common issue with most LCD monitors. usually swollen and not.
    claybv
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
