Dell Ssx2210b no backlight
  • LewMar
    • Dec 2015
    • 5
    • Portugal
    I'm trying to repair a Dell sx2210b LCD monitor. The backlight goes off instantly after turning power on. This monitor has an external power supply, I have replaced all caps in the inverter board, but that didn´t make any change.
    In order to test the inverter board with a cfl lamp, I have soldered a couple of wires in each ccfl connector on the inverter board, and just before connecting the cfl lamp, I tested once again the monitor and I found that the backlight works while I keep the wires soldered in the second ccfl connector.
    The wires are only soldered on the inverter board and nothing is connected to the other end, somehow it seems to act like a coil. If I disconnect the CCFL lamp on the connector where the wire is soldered, the backlight goes off.
    I suspect that one of the lamps is faulty and is not drawing enough current.
    Any help appreciated.
    Re: Dell Ssx2210b no backlight
    It only takes one bad lamp to trigger the protection circuit. So you have one bad lamp that is fired up but does not go into conduction.
      • 31094
      a worn lamp should draw MORE current, you may have a cracked tube or burned solder joint.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
