Viewsonic VP171b, orange screen, flickers
  • Ken256
    • Oct 2009
    • 25
    Hello. I have an old Viewsonic VP171b. When first turned on the picture had a very orange color. Within 30 seconds the orange color improved, but some orange tint remained. There was also a slight, repetitive flickering of the image. After 15 minutes all of these symptoms disappeared and the image was perfect.
    I have seen old laptops with permanently orange screens. I assumed this was caused by worn out CCFL bulbs. But I have never done CCFL replacement.
    It seems the VP171b has some warm-up or temperature dependent problem. The thought occurred to me that the power supply to the inverter/CCFL could be at fault. Maybe low voltage or bad caps causes the orange color, and flickering?
    I wonder if anyone could give opinion if these symptoms are the result of bad CCFL bulbs. I don't have the ability to bring much test equipment to the location of the monitor. Thanks!
    Re: Viewsonic VP171b, orange screen, flickers
    Sounds like worn out CCFL to me, and if you keep running it, it may take out the inverter transformer.
    Pink glow due to bad lamp, the ends of the lamps turn red hot and it will cause more melt down. The monitor this old should also have as set of caps in the power supply replaced.
    http://s807.photobucket.com/user/bud...ml?sort=3&o=29
    http://s807.photobucket.com/user/bud...?sort=3&page=2
    • Ken256
      • Oct 2009
      • 25
      OK. Thanks for sharing your CCFL pictures. Looks more like a bad CCFL bulb. Maybe not worth replacing bulbs. I'll pull them out and look. Thanks.
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
      • mosfetratus
        macbook A2918, orange light off when shut off
        by mosfetratus
        When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
        Works with battery and charges, but when i shut off i get this problem.
        It had liquid spill. Board has no corrosion, keyboard is working, power button...
        05-31-2024, 03:34 AM
      • lostone
        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
        by lostone
        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
        05-19-2024, 11:40 AM
