HP L1702 goes on and off
+ More Options
Posts
  • Lercom
    • Mar 2008
    I have a HP L1702 which when I turn it on gives good picture and then goes off after 2 seconds. The power led keeps on lid green. If I then power off and on again same result.
    This looks like the problem which many of this forum had with the Dell 173FPB, but the inverter board is completely diffrent.
    Anyone has an idea how to repair?
    Regards
    Lercom
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: HP L1702 goes on and off
    Post a few detailed photos: perhaps someone can help you.
    Zandrax
    Have an happy life.
    • olivercan
      • Mar 2008
      • 17
      HI to all of you I have same problem with me minitor hp 1702.It power up and stay on for few minutes then go off.I push again the power botton come on then 2 second off.the display and picture look ok.please help.THANkiS
      • Krankshaft
        • Jan 2007
        • 2328
        Post some pics of the inverter board so that I can get a bearing on what to check.
        • olivercan
          • Mar 2008
          • 17
          here is a picture i took.theres one more thing. when i adjust the contrast to 60 and the brightness to 20 its good for 3-2 hours and then shuts off
          • supersabre
            • Feb 2006
            • 45
            I have the same monitor with the same kind of problem.
            The backlights are very marginal, sometimes it works for hours but flickering constantly. And then after a while, the backlight shut down but still has green power led.
            I pull the a lcd panel from another 17 monitor, and it works flawlessly(turn it on for 5 days).
            If you can find the same panel, then it is fine.
            Otherwise, forget about of replacing the backlight. The screen is closely packed with the backlight, it is very difficult to take it apart without damaging the screen and leaving dust and hair inside the panel.
            • Krankshaft
              • Jan 2007
              • 2328
              I meant a picture of the inverter / power supply since thats most likely where the problem exists .
              • olivercan
                • Mar 2008
                • 17
                here is a new picture
                • Krankshaft
                  • Jan 2007
                  • 2328
                  It seems like not all of the image uploaded I only see half of it.
                  • olivercan
                    • Mar 2008
                    • 17
                    ok here it is
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      The first thing that I would do is replace all of the caps the problem you describe definately sounds like cap problem.
                      I think the caps on your board are Capxons and their quality is dodgy at best.
                      While the led remains green and the monitor is plugged into a source shine a flashlight on the LCD do you see an image? If so the main video board is fine.
                      • supersabre
                        • Feb 2006
                        • 45
                        The power board is exactly the same as my bad Hp1702. Before i replace the bad light and whole panel,I test every capxon with esr meter. All are good(0.04~0.08), so i don't think the cap is bad.
                        If you flash a beam of light on the screen and you can see picture on it, then 99% is the faulty backlight.
                        • olivercan
                          • Mar 2008
                          • 17
                          thanks for all the help.the moniter is working like a charm
                          i followed the your suggustions. i replaced the capititors and the back light.
                          heres a picture on what i changed.
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Yet another monitor saved from the landfill.
                            With a new backlight and replaced caps that monitor will last a long time.
                            Good job .
                            • calishe
                              • Jun 2008
                              olivercan, please post a picture with vga wire connected into main board and say me vga pinouts, I have two problems, VGA pinouts and may be inverter problem (monitor shotdown in 30 minutes)
                              Thank you
                              Sorry for my bad english
                              • ben_re0
                                • Jun 2008
                                Hi!
                                i have the same problem with 2 hp l1702 lcd's.
                                where can i get a new backlight to replace?
                                how do i replace it?
                                thanks alot, ben
                                • yodude010
                                  • Feb 2009
                                  • 6
                                  hello,
                                  my hp 1702 17" was working fine, but suddenly its condition changed, when i turn it on, green light comes, i can see the image only for 1 or half second and it again disappears and reappears and this thing continues. The picture is fine but the screen keeps on blinking, the light is green, even the computer is turned off, this process continues.
                                  What do you guys prefer me to do?
                                  replace caps or what?
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Originally posted by yodude010
                                    hello,
                                    Inspect them first. It may be a cap problem, or it can be a CCFL. Pics help
                                    There are 10 kind of people in this world: those that understand binary, and those who don't.
                                    • ASUS ROG Maximus IX Code
                                    • Intel Core i5-7600K 3.8GHz
                                    • 16gb GSKILL TridentZ RGB DDR4-3200
                                    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                                    • Windows 10 Pro x64
                                    • GeForce GT1050
                                      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                                    • dvorav
                                      • Oct 2008
                                      • 43
                                      Hi to all,
                                      I got one HP 1702 recently. It has a similar problem. After switching it on, there is picture for lets say 1-2 sec, with outgoing such a scratchy sound. Then it goes off (power LED is not shining).
                                      I measured around 310V on main capacitor. But when disconnecting it, it stays charged for a long time (tents of minutes). So I measured starting resistors. They are two and have 0.6M Ohm in series. It seems good.
                                      The rest of capacitors looks fine, none swollen or so. (They are KZE green ones).
                                      Any ideas what to do?
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Originally posted by dvorav
                                        Hi to all,
                                        Not just the BL, ALL goes off?
                                        • GeForce GT1050
                                        • Chrissygizmo
                                          Can i use backlights from a diffrent model tv to work mine ?
                                          by Chrissygizmo
                                          Hi all , bit of a strange one for yous here lol , ive got a samsung ue49ru7300k , backlights need replaced , however ive got some backlights from another samsung tv , i will post photos of them .. the connectors are the same & everything so im guessing they could work...
                                          11-07-2024, 03:16 AM
                                        • dome1
                                          A1708 Weird boot behaviour
                                          by dome1
                                          Hello!
                                          This is my first post here.
                                          Recently i repaired my costumers a1708, 820-00875. Where U3200 was in short, it got replaced, device started working again without problems. Fastforward 4 months and it has problems with booting.
                                          Sometimes it shows apple logo, is stuck, then shows a crash screen
                                          Sometimes it just boots normally
                                          It wont allow me boot externaly, Tried 3 diffrent osx, Bigsur, Monterey, Ventura.
                                          From what i gather i assume bios is corrupted, but what programmer do i use? where do i begin? Any help is welcome...
                                          06-29-2023, 08:48 AM
                                        • playaskillz204
                                          Microsoft Surface Bios Administration password !
                                          by playaskillz204
                                          Hello I have a Surface 8 Pro that has a Administration lock on it and it wont allow me to reinstall the OS when i try to use usb recovery OS install it still wont install. I do happen to have a usb bios flash tool its CH341A programmer. would this be suitable for unlocking this Administration password if i backup the bios ? or do i need a diffrent programmer. im fairly new to this. is there another way to do this 😭 i can boot HirensPE usb but when i try custom windows 11 pro x64 install(Not from Ms) is blocks the Install. plz help with any info anyone can provide thank you 🙏...
                                          02-11-2025, 01:37 PM
                                        • 3aris
                                          TOSHİBA L505 V13 SHUTDOWN
                                          by 3aris
                                          TOSHİBA L505 V13 NSWAA LA-5322P
                                          İt s starting with fan windows loading or entering bios after 10-15 second fan rising after shutdown
                                          l tired 2-3 times bios dump diffrent codes
                                          1-TOSHIBA SATELLITE PRO L550 NSWAA LA 5322P REV 1.0
                                          2-SAT L505 LA-5322P
                                          01-15-2025, 09:11 AM
                                        • ebyte64
                                          Bios request for Acer P214-52-58CH
                                          by ebyte64
                                          Good day.
                                          I would like to request a bios for the following laptop?
                                          Model: Acer P214-52-58CH
                                          Model No: N19Q7
                                          S/N: NXVLHE0H11204BA27600
                                          SNID: 11201936276
                                          Symptoms: Laptop powers on but no picture on screen.
                                          I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                                          09-25-2024, 05:59 AM
