A1708 Weird boot behaviour
  • dome1
    • May 2023
    • BelgiĆ«
    Hello!
    This is my first post here.
    Recently i repaired my costumers a1708, 820-00875. Where U3200 was in short, it got replaced, device started working again without problems. Fastforward 4 months and it has problems with booting.
    Sometimes it shows apple logo, is stuck, then shows a crash screen
    Sometimes it just boots normally
    It wont allow me boot externaly, Tried 3 diffrent osx, Bigsur, Monterey, Ventura.
    From what i gather i assume bios is corrupted, but what programmer do i use? where do i begin? Any help is welcome
    @Edit
    Already tried diffrent internal ssd, the smc/pram reset.
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Re: A1708 Weird boot behaviour
    Did u already try Command + R? re-install system via online? secure boot on this macbook is activated i suppose, that's why dont allow u to boot an external HDD?
    if you are pressing Command + R and does not get you in the recovery menu try this: plug in an external HDD with diferent mac os installers and try again Command + R.
    • estabilito
      Acer Nitro AN515-55 weird behaviour on startup
      by estabilito
      Hi, I've just repaired acer nitro an515-55 with specs:
      i7-10750h, rtx2060.
      Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
      After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
      i've tried different bios, different vbios and same behaviour - clean windows install too.
      Do you have any idea?
      08-13-2025, 02:52 PM
    • lukkihapsi
      Asus Vivobook X515JA Weird Boot Issue
      by lukkihapsi
      Asus Vivobook X515JA Laptop
      Issue :
      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
      Tried :
      Cleaned inside for dust, applied fresh thermal paste. No Change!
      Removed keyboard, Trackpad, fingerprint sensor. No Change!
      Removed Internal SSD. No Change!
      Updated BIOS to latest version. No Change!
      Removed battery and pressing power button for 1 minute. No Change!
      Weird Part :
      Upon turning laptop ON, screen lights up - stays black,
      I...
      07-07-2025, 12:07 PM
    • ahoonid
      A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
      by ahoonid
      Hi everyone.
      I have MacBook Pro A1708 with a confusing issue.
      The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
      Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
      I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
      The initial issue however remains.
      No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
      05-10-2025, 04:19 PM
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
    • hinisa
      Xiaomi router freezes at boot after re-capping
      by hinisa
      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
      07-08-2023, 05:58 AM
