Samsung monitor 2493 HM steady blue light dead
  • ivtec
    • Dec 2008
    • 1967
    Re: Samsung monitor 2493 HM steady blue light dead
    Originally posted by budm
    There are 5 small electrolytics caps close by the SMPS ICB801S that should be check for ESR and capacitance, or just replace them if you do not have ESR/Capacitance meter.
    Thanks again budm; i checked all those little caps and all of the others with my Cap Analyzer 88A and all check good ,
    but i checked this SM resistor 104 that measures 4K it should be 100K next to C809 there is another 104 in same area that measure about 95K what is about right,i would post Board # of these SM resistors but they are hard to reed.
    • ivtec
      • Dec 2008
      • 1967
      Hi budm here some pics of my board and the resistors i'm talking about please help
      • ivtec
        • Dec 2008
        • 1967
        Hi budm did you give up on my issue ,please give more advice,thanks
        • ivtec
          • Dec 2008
          • 1967
          H guys new update on Samsung 2493 HM monitor.
          Today i decided to reassemble power supply after taken out Cap 4pf 1KV
          clean hard glue and re-solder it back also cleaned all other glue around all other caps,
          and for my surprise i have tv on but with no controls and just a screen with switching back and forth between RGB ,white,and blue screen,with no controls on the front,just power on and of switch,see video,
          what do you see of this? thanks in advance
          Disregard the sound cause is from my tv.
          https://www.youtube.com/watch?v=NgBQ...ature=youtu.be
          • ivtec
            • Dec 2008
            • 1967
            I connected HDM i Cable and i have also sound
              Never mind after reading you r post 24. I thought you had already removed all the glues as suggested in the beginning.
              The resistor is in parallel with the load so it will show <100K.
              I would check out those semiconductors I marked.
              Check those Resistor, Diode, Cap in the snubber network, see some glues there.
              Check the fusible resistor, should be <10 Ohms.
              • ivtec
                • Dec 2008
                • 1967
                Thanks budm; i checked those and they seem ok although the solders on these are not very good so i touched them up,
                now i want your opinion on a SMt Cap 470uf 16T C3045 on the main board,between L600 and L902 see video. also on cap 470uf the 16T stands for 16v?
                https://www.youtube.com/watch?v=csbe...ature=youtu.be
                The Fusivel resistor RB 8015 you mention is not 10 ohms but 33ohms
                  You can measure the DCV between the two legs of the cap, then you will have some idea what the Voltage rating of the cap will be.
                  • ivtec
                    • Dec 2008
                    • 1967
                    did you check the video i made about the the cap if the short is due to the 2 coils?
                    also The Fusivel resistor RB 8015 you mention is not 10 ohms but 33ohms
                    • ivtec
                      • Dec 2008
                      • 1967
                      https://www.youtube.com/watch?v=NgBQI5Wnzi4 -
                        The Video wants me to sign in to see the video.
                        This is what I see when I click on the link:
                        The first link:
                        'This video does not exist.'
                        The second link:
                        'Content Warning
                        If the owner of this video has granted you access, please sign in.'
                        'The Fusivel resistor RB 8015 you mention is not 10 ohms but 33ohms'. i just check the board, you are correct, it is 33 Ohms not 10 Ohms.
                        • ivtec
                          • Dec 2008
                          • 1967
                          The first link:
                          The second link:
                          'Content Warning
                          Sorry budm i can see the video perfect,i don't know why this.Type; frank Silva inside YouTube that's my chan.
                          • ivtec
                            • Dec 2008
                            • 1967
                            https://www.youtube.com/edit?video_i...m-upload_owner
                              One account. All of Google.
                              Sign in to continue to YouTube.
                              • ivtec
                                • Dec 2008
                                • 1967
                                Sorry budm but is there any other way i can post the video?
                                https://www.youtube.com/watch?v=csbeLRLHfKk
                                  OK, it is working now. What did you change?
                                  You are testing the cap that is still soldered to the board, other components connected in parallel with the cap may be giving you wrong reading.
                                  The '470' can also mean 47uF, it depends on how manufacturer uses the numbering system. some may use '471' for 470uF (1 = multiplier of 10).
                                  I am not sure about the first Video that shows color cycling.
                                  • ivtec
                                    • Dec 2008
                                    • 1967
                                    Thanks budm the cap is 470 uf cause i have another one just like it and with my Fluke 87 i measure about 470uf, the 16T i would assume it's 16v.
                                    Also this is the other video it's not my tv but it's exact the same symptoms. hope you can open it.
                                    https://www.youtube.com/watch?v=5ulXm4Wix5k
                                    • ivtec
                                      • Dec 2008
                                      • 1967
                                      https://www.youtube.com/watch?v=41ThS6hubdg
                                      • ivtec
                                        • Dec 2008
                                        • 1967
                                        Hi budm; i have good news, i opened up the monitor one more time and i went through some of the solders and found one bad solder on one of the caps re-solder it and reassembled it and for my surprise monitor is working again like new,as i stated all components all looked and tested ok,so it had to do with the hard glue and bad solders.Thanks budm for your patience and time, appreciate,this forum is the best.
                                          The symptom shown on the youtube is very strange, they all have the same symptom. I wonder it was due to bad DCV feeding the main board or not. Glad it is working out for you and you did not give up.
