AOC 913Swl has a white screen.
  • Neshone
    • Oct 2015
    • 23
    • Bosnia and Hercegovina
    I have monitor AOC 913Swl. It has problem with white screen like this:
    https://www.youtube.com/watch?v=KF43WKaZBEk
    I try erase contacts on flat cable like on this video:
    http://www.youtube.com/watch?v=FfbmQRuqDD0
    But it didn't help.
    I check PSU board and I think that it's good. All Voltages seams good. (Only on 12V pins I have 14.90V)
    I can post all voltages if that is required
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: AOC 913Swl has a white screen.
    Likely T-con board issue. Check fuse on T-con board. It should be near the LVDS connector. The T-con board is the one that is attached to the LCD display TFT matrix.
    If possible, post some clear pictures of the T-con, so we can assist you further. Use the forum's "Manage Attachments" (found after clicking the "Go Advanced" button) feature to submit your pictures.
    • Neshone
      • Oct 2015
      • 23
      Tnx momaka for your reply
      I searched fuse on all boards but without success.
      In this post I will attach images of all board and original image of screen.
      This AOC 913Swl was broken before 5 months. I left him in basement.
      After 5 months I try again and all was alright first 1-2 min. Later problem returned.
      The Screen has very slow response and if I change screen image(for example, pres CTRL+ALT+DEL) on display screen change after several second and change very slow.
      I don't know what is 6R4 M16, but that is suspiciously.
      • 1supertech
        • Apr 2012
        • 384
        In the fourth pic from left fuse is F1 it has P15 written on it I think tab bonds are going bad.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Ah okay, I see that this is not a complete white screen problem - just washed out.
          In that case, the fuse on the T-con board is likely NOT the problem (which is F1, with "P15" written on it, as 1supertech pointed out. Still, check it just in case with your multimeter. It should have good continuity. 1-2 Ohms resistance max (or less, depending on how good your multimeter is).
          I'm thinking this is likely NOT tab bonds either, since the whole screen seems to be affected and there are no vertical lines.
          Try this: when you press the "MENU" button on the monitor, does the OSD also appear with strange colors too?
          Another test to run is to check the voltages on the T-con board (that is the board in picture #4 you posted). There are small golden dots on your T-con board - these are voltage test points. What you need to do is use your multimeter to measure the voltage between ground (monitor metal chassis) and the following test points:
          VDD (located right below fuse F1)
          AVDO (located top right of that "6R4 M16" inductor")
          VGH (I can't find it on your board, but it should be there. Sometimes called V_GON or VDDG)
          VGL (I can't find it on your board, but it should be there. Sometimes called V_GOFF or VEEG)
          The problem could also be bad gamma IC, I think. If you can, please post a full picture of the T-con board.
          Changing the electrolytic capacitors on the video/logic board (picture #2 you posted) could also be the problem.
          Sorry I can't give you more exact guidance where the problem is. I've seen problems like this before and often times they either couldn't be solved or the problem was different for each one, so there were different solutions. Hopefully, the above tests should help determine where the problem could be.
          • Neshone
            • Oct 2015
            • 23
            I check the voltages on board:
            VDD=5.04V
            AVDO=12.65V
            VGH=27.8V
            VGL=25.4V
            Resistance of the fuse F1 is about 0.7ohms.
            When I press MENU button colours are strange and it have slow respons.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              VGL=25.4V
              And that might be it.
              VGL is usually -5 to -10 Volts. It is responsible for making pixels in the LCD appear dark (whereas VGH turns them ON and makes them pass-through the backlight).
              Speaking of which, I can't find where test point VGL is on your T-con. Could you point it out to me. I know there should be one somewhere if there is VGH.
              Basically, bad VGL could be caused by a bad transistor, bad diode, or shorted ceramic capacitor. Once I know where VGL is, I should be able to point it out to you which components to check.
              • Neshone
                • Oct 2015
                • 23
                I check now and MGL=24.4V, but I can't find VGL,V_GOFF or VEEG.
                I checked several times but nothing...
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Okay, I see some test points called VOFF, VOFF1, VOFF2, and VOFF3. Check those. If you don't see a negative voltage there, can you list all of the test points you see on the board? Your pictures are a bit out of focus, so I can't read some of the test point names.
                  By the way, I don't see a test point called MGL either. I see MLG. Not that it matters, I just wanted to point out how tricky it can get to read those small test points sometimes even with the board in front of you.
                  • Neshone
                    • Oct 2015
                    • 23
                    Test points are:
                    RP2
                    OUT1
                    MLG
                    LV0, LV1, LV2, LV3, LV4, LV5
                    LV0+, LV1+, LV2+, LV3+, LV4+, LV5+
                    OUT684
                    VOFF1, VOFF2, VOFF3
                    VGH
                    XON
                    AVDOS
                    SW
                    OUT605
                    OUT1368
                    VDO
                    RX0+, RX1+, RX2+, RXCLT+, RX3+
                    RX0, RX1, RX2, RXCLT, RX3
                    DVDOS
                    DVDO
                    OUT1338
                    OE1CPV
                    AGING
                    OE2
                    TEST
                    MPOL
                    LOAD
                    OUT2053
                    OUT2736
                    V1, V2, V3, V4, V5, V6, V7
                    OUT2737
                    OUT3420
                    V8, V9, V10, V11, V12, V13, V14
                    PWRC2
                    PWRC1
                    CSC
                    OUT4104
                    LV1P
                    LVCKP
                    LV4P, LV0P, LV2P, LV3P, LV5P
                    LV1N, LV4N, LVON, LV2N, LV3N, LV5N
                    That's all
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      That's all
                      Yes, seems like it.
                      Okay, so check the voltages on VOFF, VOFF1, VOFF2, and VOFF3. There has to be a negative voltage with respect to ground on one of these test points. At least I haven't seen an LCD t-con board without one.
                      • Neshone
                        • Oct 2015
                        • 23
                        Voltage on all VOFF are same and it's -7,66V
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Good voltage ^ .
                          Unfortunately, that means the problem is likely caused either by IC0/IC1 or the LCD panel is bad.
                          Can you post the part number on IC0? I believe that should be the gamma IC. IC1 is Novatek NT71206FG, but I can't find a datasheet anywhere for it to see what it does. Good news is that you can find it for sale online.
                          Also, try cleaning the contacts one more time. Maybe use some isopropyl alcohol too. And make sure the solder joints on the connector(s) looks good and not cracked.
                          • Neshone
                            • Oct 2015
                            • 23
                            Ic0 -
                            g16
                            1287
                            ic1 -
                            nt71206f6-603
                            1139-66
                            d5sr1
                            ic4
                            gh17k
                            132n61
                            ic5
                            17075e
                            tg133
                            I try cleaning the contacts... but nothing...
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Okay, I can't find a datasheet for IC0, but it doesn't look like the gamma IC, so that is probably not the problem. That means IC1 is likely the gamma IC.
                              IC4 is a linear voltage regulator, probably for IC1 and IC0. Check the voltage on the input of IC4 (the right-most pin) and the output voltage (center-pin or tab on top). Report what values you get.
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • kca
                                by kca
                                Hello all ~
                                08-31-2025, 06:38 AM
                              • harp
                                White screen repairs
                                by harp
                                To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                05-13-2024, 03:43 AM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
