Elo E123233, 1 Green LED, no sound, blank screen, not recognized by PC
  • mekboy101
    • Sep 2015
    • 10
    Hi everyone, I inherited an Elo touch screen monitor from work and as it was going to go to the junk yard i figured id try and save it since it was once a nice monitor, and it doesnt appear to be very old.
    I get nothing when i press the power button, no flickers even in pitch black.
    (it does have 2 status LEDs located on the bottom of the monitor one of which lights up as soon as the power cable is plugged in)
    I took the LCD assembly and plugged it into another monitor and inverter and it displayed an image perfectly.
    If i disconnect CN05 which leads to the video board, the touch board's LED's start lighting up and flashing, and the 2nd LED located on the bottom of the monitor starts lighting up green and blinking.
    I am getting about 3.275v on all the pins (except ground) at CN02 on the video board which goes to the power/display buttons on the side of the monitor.I dont know if thats a normal voltage for a power button or not.
    My suspicion is the issue is with the video board or the power button but i have no idea how to go about proving this.
    Any help/thoughts on what i could try would be greatly appreciated!
    Thanks to anyone who has time to help!
  • 1supertech
    • Apr 2012
    • 384
    Re: Elo E123233, 1 Green LED, no sound, blank screen, not recognized by PC
    Did you Check fuse on mainboard F202
    • mekboy101
      • Sep 2015
      • 10
      both f201 and f202 read 0.000 and beep (fluke 11 DMM) when checking for continuity.
      Thank you for your suggestion!
      • mekboy101
        • Sep 2015
        • 10
        Would anyone happen to know a good place to find the audio/video mainboard where i would buy a replacement? I've checked Ebay and searched for the part number on google but im not finding anything.
        It seems the sites that say they stock it, look like they are for manufacturers as there's a "Target price" listed. Do you think they would sell qty 1? to individuals?
        part on back of the mainboard says "E144591 PCBA Rev H"
          • 30977
          i will tell you one thing,
          i would replace all the caps on the left side of the video board with panasonic FR series.
          that design will cook the caps in that area.
          • mekboy101
            • Sep 2015
            • 10
            Ill give that a go! thank you for the advice!
            • MOSSEP
              Monitor Audio RSW12 - Green light, but no sound
              by MOSSEP
              Hi
              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
              I have already tried replacing all of the...
              01-26-2025, 08:33 AM
            • RetroComputingGrotto
              Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
              by RetroComputingGrotto
              I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
              I've uploaded a video of it happening on YouTube:
              I've taken the monitor...
              01-11-2024, 05:37 AM
            • arctor
              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
              by arctor
              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
              04-26-2025, 05:22 AM
            • mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
              by mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
              11-25-2024, 05:22 PM
            • matthewmcconaughey
              I need help with my friend Sony GDM-FW900 24” CRT
              by matthewmcconaughey
              Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
              I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
              1. It started with a bright and greenish picture upon starting a cold monitor.
              2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
              05-16-2023, 03:15 PM
