HP 2510i ... dimmed picture
  • Porto
    • May 2015
    • 109
    • NL
    What I got here is a beautiful 25", 16:9 HP 2510i screen which I repaired awhile ago. It's working great but there is one problem left, the screen is quite dimmed and brightness control is already at its highest. In comparison with my own 24" HP w2408h screen, the brightness on the 25" is just merely half of it.
    Is this normally a problem with the installed CCFL's (old, worn) or do I have to check the inverter board?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: HP 2510i ... dimmed picture
    Possibly Cfls or I have had a case where there was a faulty transformer on the inverter Pcb.
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • arbitarytwist
      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
      by arbitarytwist
      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
      03-01-2025, 01:16 PM
    • nasdaa
      Packard Bell Kayfo, no picture on screen.
      by nasdaa
      Hello, I need your help for a failure on a laptop:
      It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
      I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
      06-20-2023, 01:27 AM
    • burbutsalos
      LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
      by burbutsalos
      Hello everyone.
      I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
      The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
      The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
      The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
      The effect is there even on a completely black screen.
      The screen...
      10-21-2023, 02:57 AM
