My HDTV won't detect my computer Help!
  • YeOldeGinge
    • Nov 2014
    • 30
    • Telford and Wrekin
    Right I have a Technika x22/14b-gb-tcd-uk HDTV that I am trying to connect to my computer as a primary Monitor I already have a Technika x22/14c-gw-tcd-UK which is a slightly different model that works great as a monitor but I want the other HDTV to work too.
    The HDTV is not detecting the computer which is connected via hdmi as it keeps saying no signal on the TV and the HDTV does't show up in device manager on the computer so I am thinking that the HDTV isn't compatible with my computer or something as I have tried it on my old computer and works fine and have also used different hdmi cables and nothing changes.
    Please Help Me :P
  • halobender
    • Apr 2013
    • 36
    Re: My HDTV won't detect my computer Help!
    Update your video drivers on your computer. Verify the HDMI port is working by connecting to another device. If using win vista + and if still not working try to force find the TV by pressing windows key + p and tell it to connect to a projector and pick the hdmi output.
    Good luck!
    • YeOldeGinge
      • Nov 2014
      • 30
      Good luck!
      I have tried connecting the TV to another device and it works fine as I used to use it as a secondary monitor on my old computer and I'm running windows 8.1 when I click win + p I select extend and it does nothing as you can see in the image below the screen is not being picked up at all the generic pnp monitor is my primary monitor
        by momaka
        03-15-2023, 10:17 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
        by Rick_1234
        Good evening, gentlemen.
        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
        https://drive.google.com/file/d/1L6S...ew?usp=sharing
        Things I tried
        - Bought a new AC adapter thinking that was the problem but the problem...
        06-22-2024, 04:44 PM
        Wise Wing F199 19'' LCD monitor - recapped
        by momaka
        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
        When I saw the Craigslist post, I wasn't...
        08-24-2020, 10:58 AM
      • sew333
        Pc shutdown, monitor flickered with no signal after 10 seconds
        by sew333
        My pc:
        10850K stock 4800mhz stock Kraken X73 good temps
        2x16 GB DDR4 GSKILL 3000mhz XMP
        Seasonic Tx-850 Ultra Titanium
        Gigabyte Rtx 3090 Gaming OC
        Aorus Z490 Pro Gaming
        1 TB SSD
        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
        Power...
        02-22-2022, 10:27 AM
