Asus k52jr no backlight
  • raider988
    • Jul 2015
    • 49
    • Eu
    I am not an expert on hardware, but I do my best and I'm here to learn so please be patient, every little step is my first step in this.
    I have trouble with my laptop, motherboard model k52jr, LCD led screen model lp156wh2. I have isolated the problem to the backlight, computer works perfectly with external monitor plugged in, the native screen works except for the backlight and I can see the desktop if I shine light on screen.
    I did some research and find out about multimeters, how they works, what they do, so I bought one at a fair price and started doing some tests.
    I downloaded the specs for my screen, but I was unable to take measurements on the 40 pins on the back of the screen, everything is simply too small, so I had no idea which pin receives what. I checked the screen plug on the motherboard instead, but I counted only 30 pins on it. Anyway, a couple of them reported 19.4 volts (I connected one end of the multimeter to the ground), so I guess the motherboard is doing its job.
    I checked voltages on the back of the screen then, i found an F1 and an F2 fuse. They passed continuity but when the screen was plugged in they measured 19.4 volts instead of the 32 written on the board. I check VLED and VLED_OUT and they both get 19.1-19.3v.
    At this point I don't know how to isolate the problem a little more and get closer to the solution, I am aware that i probably made it simpler than it is, but that's precisely why I'm asking for your help.
    I suspect it might be the led strip itself, since everything seems powered on, but i have no way to test them directly.
    Any kind of insight is very welcome, I attached some pictures if you wanna take a look.
    Thanks a lot guys
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Asus k52jr no backlight
    19 volts on back of the screen is ok. For the LEDs to turn on you need a couple more pins to be 3.3v, specifically LED_EN and PWM. Pins 36 and 35 on the back of the LCD connector. See here for reference: http://s599.photobucket.com/user/Chr...l?t=1332836621 You are most likely to find that you are missing LED_EN.
    A bad screen or a bad LCD cable can cause this. I have a similar Asus laptop in for servicing where the screen shorted out LED_EN and melted the wire in the LVDS cable, so this one it's going to need both a new screen and a new cable. Yours might be luckier.
    A working TV? How boring!
    • raider988
      • Jul 2015
      • 49
      • Eu
      First, thank you so much for the suggestion!
      So, I got a thinner probe and took those measuments. I don't know how can you do it for a living guys, I had a hell of a time to measure those tiny pins and I couldn't have done with some help to take the readings and write them down. I double checked them just to be sure.
      This is what I got:
      35 ==> 3.3
      36 ==> 3.2
      37 ==> 0
      38 ==> 19.2
      39 ==> 19.2
      40 ==> 19.2
      So i got luckier than the Asus you repaired and I think I can assume that whatever is not doing its job lies on the screen, but correct me me if I'm wrong, I might not being considering things I don't know.
      A big part of the problem is that i know nothing about the circumstances that lead to the backlight failure, a friend took this laptop to a technician for a keyboard issue and it came back with the backlight problem. So she came to me to recover her datas and left the laptop as a present. I don't really need it to get fixed imediately, I think this is a great chance to start experimenting and learning without paying any real consequences if I fuck up big time, however it goes I want to learn a big deal in the end.
      Any other suggestion is greatly appreciated, I'd like to concentrate in finding a way to test those leds since they seem to be the next best candidate for backlight failure.
      I found this page which describes an reletively approchable way to test the led circuitry, which gets close to what I want to do, but it's not really that.
      I'd like to feed energy directly into the led strip itself, so first I need to know which are the points where i should stick my pos and neg, which voltage and amperage I need to get even a glimpse of light from them.
      • raider988
        • Jul 2015
        • 49
        • Eu
        UPDATE:
        I took it one step further and measure voltages directly on the led strip socket and I got those values (image attached):
        1==> 19.1
        2==> 19.1
        3 to 9==> 0
        Can I safely assume that the led strip itself is not working anymore?
        If yes, what may have caused the problem in the first place and how can I be sure I won't have the same problem once I replace them?
        • raider988
          • Jul 2015
          • 49
          • Eu
          Update 2
          I took out the led strip trying to check voltages on the leds themselves and something strange happened.
          I connected the back probe on the ground as usual, when i put my red probe on the side of one led it lit up, and other leds every 5 or 6 too. The more I moved away from the plug, the more bright they became, but never as bright as they should be. When i moved to the last led i got the highest value of 16.4v, while the first was 0.8. I check
          every led and they all work.
          At this point I'm lost.
          • raider988
            • Jul 2015
            • 49
            • Eu
            After couple years a lots of learning I took back my old screen and gave it a look.
            The ribbon cable was damaged. I have no idea where because it's not visible, but that's it.
            Thank you all for the help!
            • platinumsteel
              • May 2019
              • 234
              • Trinidad&Tobago
              This help me resurrect a Dell Inspiron 3000 Series Screen that would not give backlight only picture. On the screen itself on the bottom raised the plastic paper and on the test points LED_EN and PWM was missing just like Th3_uN1Qu3 mentioned. Those 2 are very important for Backlight. So i took a jump from a test point called Acc that had 3.3V and jumped LED_EN and PWM together and now I have full backlight working. One thing to note at first I only jumped LED_EN with the 3.3v and i didn't get any backlight. Only when i jumped both LED_EN and PWM i was able to get full backlight working. Thanks a lot uNiQu3 for pointing this out.
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • HTR-Informatique
                by HTR-Informatique
                02-09-2025, 06:51 AM
              • frannyjunk
                Hisense 40H4F no backlight but turns off after splash screen
                by frannyjunk
                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                TIA.
                09-24-2025, 10:59 AM
              • Spoonicks
                ASUS VH238T blank screen with backlight
                by Spoonicks
                I am having a problem with a ASUS VH238T.
                The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                07-04-2023, 01:29 PM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
