Apple LED Cinema Display 24" (A1267)
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This nice 1920x1200 monitor has dead backlight. Image correctly formed on LCD but no backlight. His owner says that last days it was working it got unusually hot in the lower side.
    Once opened, I detect a short mosfet (540N ?) and a short diode, plus a perforated IC [U0815] (cannot read its name as the perforation is precisely there). I don't have schematics (Apple service manual considers that nobody will repair it at component level) but I assume that [U0815] is a controller for 3 power LED drivers, one for each LED strip at the panel (LCD panel LM240WU6(SD)(A1), with 3 LED strips). Shorted mosfet and diode belong to a single power driver circuit.
    I attach image with interesting spots. Damaged driver circuit is the middle one (transistor disconnected and diode already stripped).
    Since [U0815] is irreplaceable to me, I'm forced to replace logic board, BUT, I'm afraid that there's something at middle LED strip that caused this failure to the driver and controller, so changing logic board would be a poor long term investment...
    And then the question: how can I cheaply test each LED strip to be sure that they're OK before buying a new board? According to panel datasheet each strip needs about 60V and 350mA.
    Update: after finding this identical case, I get to know that controller is a HV9982. He doesn't explain if the repair was successful. Actually, he didn't even say that he was repairing this kind of monitor!
  • Porto
    • May 2015
    • 109
    • NL
    Re: Apple LED Cinema Display 24" (A1267)
    If your lab power bench can't reach 60v DC, maybe you can build a small circuit which inputs Mains voltage, rectify that AC to DC voltage and lower the voltage with a few 2W resistors.
    I have a power supply of some monitor here which does exactly that to get the voltage from 230v DC to 90v DC; they used 3 resistors in serie to get the voltage down in steps, thus not using one big resistor, maybe for heat dissipation reason or something.
    Or create something with a step-up transformer.
      You should check the resistance between the chassis and each pin of that LED connector (connector not connected to the board) to see if any one of those wires going to the LED strips inside is shorted to the chassis or not.
      If I remember it correctly those 3 Power MOSFETs are for the Boost converter to create the drive Voltage for the LED strings.
      http://s807.photobucket.com/user/bud...?sort=3&page=1
      • Chungalin
        • Jul 2014
        • 422
        • Spain
        I don't think it's that easy. My lab power supply just reaches 20V. But I think that when dealing with LEDs, the important point is current, not voltage. Without intensity control, I'll damage LED strips.
        Budm, I already checked for shorts. I don't detect anything in the range of 20MΩ, not even between any pin and chassis, or between any pin and each other.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          Both. You need enough voltage to overcome the forward voltage drop of the LEDs, but also something to limit the current too.
          -David VanHorn
          • Chungalin
            • Jul 2014
            • 422
            • Spain
            I think that my best chance is to try replacing HV9982 and then I'll have two functional LED drivers (the middle one is bad). This will allow me to test each LED strip independently and detect anomalies (overheating, low light level, etc.).
              It will probably go into safety shutdown if any one of the 3 is not on, so you may only see the LEDs flash on for seconds. Probably should look at the IC spec to see how it functions.
              • cheebster
                • May 2008
                • 373
                Any news on this one ?
                • Chungalin
                  • Jul 2014
                  • 422
                  • Spain
                  Since I couldn't dessolder HV9982 with my tools, we ordered a new Logic Board (PN# 661-4823).
                  Replaced, monitor works fine. Lower part of LCD panel (where the LEDs are) is getting pretty hot, but I don't know what is "normal". There's a temp sensor sticked right there, so it's expected to be a hotspot. Time will tell...
                  • stewart710
                    • Jun 2006
                    • 42
                    Hi, sorry to resurrect an old thread, but I have nearly the same issue but my HV9982 doesn't look damaged at all and instead of the middle led driver circuit being affected, my problem is only with the one nearest the HV9982 at the top of the picture. The obviously burnt out components are two schottky diodes marked 238C 2100b. Marking is Secos? https://cdn.badcaps-static.com/pdfs/...cbc964e3eb.pdf
                    and one mosfet marked 540N 88KEG. I tested them and they are definitely shorted closed now.
                    These are the replacement parts I was about to order from Digikey, does anyone know if they are good replacements for the 24" Apple Cinema Display LED 2008?
                    IRF540NSTRLPBFCT-ND
                    https://cdn.badcaps-static.com/pdfs/...3d1f973e5c.pdf
                    SS2H10-E3/5BTGICT-ND
                    https://cdn.badcaps-static.com/pdfs/...94309672b8.pdf
                    Thanks.
                    • Toad555
                      • Apr 2017
                      Hi, Is this still in progress for you Stewart?
                      I'm trying to repair the same screen.
                      Are you seeing any voltage to the LED strips at all?
                      If so what?
                      IRF540NSTRLPBFCT-ND
                      Thanks.
                      • zielog
                        • Nov 2017
                        Hello, I'm new to this forum. I've also got the problem you are describing. I checked the voltage at the LED driver connector. The voltage is 24.5 V. In the LG display spec it says that the voltage is above 60 V. Can any one say that the voltage is with a working display?
                        • a_p3rson
                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                          by a_p3rson
                          Hi there,
                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                          This daughterboard uses an interesting...
                          04-21-2025, 11:41 PM
                        • edugimeno
                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                          by edugimeno
                          Hi There!
                          I'm trying to help my friend who owns a restaurant be just bought.
                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                          09-05-2024, 09:34 AM
                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-12-2024, 02:30 PM
                          HP ProBook 450 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Apple AirPods Pro boardview and 450 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                          09-06-2024, 07:50 PM
                          HP EliteBook 850 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 850 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Apple AirPods Pro boardview and 850 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
