Dual LCD backlight inverter sensitive to backlight connections
  • japlytic
    • Oct 2005
    • 2086
    On a Mitsubishi AA084VC03 LCD (twin backlight) and a JX-02S210 V3.3 inverter module (the only two ICs were a common KA7500/TL494 PWM controller and a dual MOSFET for driving the transformer) for an LCD conversion of an oscilloscope, I had the problem of the backlight flashing on briefly then off in a loop with a bit of fizzing noise.
    I tried reworking all of the solder joints (initially with the power connector) to no avail, even though the LCD module was well grounded .
    Initially, I connected the LCD module with upper backlight connected to the backlight connector furtherest away from the transformer on the inverter module and the lower backlight connected to the backlight connector closest to the transformer; the backlight connector closest to the transformer only has one connection and therefore, this backlight has to rely on parasitic capacitance to illuminate.
    When I connected the upper backlight furtherest away from the transformer and the lower backlight closest to the transformer, the backlight reliably illuminates .
    Therefore, in theory, the VGA-LCD controller (Roward RTMC7C) could be sensing an overcurrent condition (+12V line with current sensing) with the backlight inverter; between the controller and the backlight inverter are three wires, Ground, +12V and Enable (+5V=ON).
    So could some backlight inverters be sensitive to what backlight you connect to each backlight connector?
    Re: Dual LCD backlight inverter sensitive to backlight connections
    "this backlight has to rely on parasitic capacitance to illuminate." I do not think so, the return wire from the lamp may be tied to the chassis some where that you are not seeing.
    " fizzing noise." do you also smell Ozone? I t sounds like the bad connection to the lamp's end.
    Any good clear pictures of what you are working on?
      • 31214
      if this is a conversion, why arent you using led's instead of tubes anyway?
      i'm just starting a conversion myself.
      satellite alignment meter.
      going from a 4inch monochrome crt to a colour lcd with led backlight.
      (it was dropped and the tube is internally fucked - incase your wondering)
      one of these:
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • jimbofz
        lg 32LC46 backlight inverter board fault
        by jimbofz
        Hi this oldie had no backlight .after replacing caps on 24v rail ,
        still no b/l this uses inverter type:1315 B1-16A,
        im sure ive come across the same inverter in a samsung possibly le32r88bd ?
        all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
        this allows protect to be temporary overridden.
        b/l now comes on
        but the left hand side of pic is gradually darker than the right side
        i have the cct for the tv
        but it does not have inverter cct.
        i opened it up to inspect the ccfl tubes
        and they dont have any...
        12-19-2021, 06:58 AM
      • caseyjay_48
        Sony KDL-46BX450 Inverter Troubleshoot Logic
        by caseyjay_48
        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
        09-23-2022, 08:08 PM
