HP w1907
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: HP w1907
    Originally posted by willawake
    interesting there is so much difference. i wonder if the monitor's vga circuits are poor.
    Not always: vga signals on videocard are filtered by a low-pass filter in order to reduce emi and to obtain an FCC certification.
    On cheap boards these filters (usually a series of capacitors and inductors near the vga connector) employs low-grade components, so the screen results is usually dizzy, the sharpness is low, colors can be altered and so on. Matrox cards, Ati-manufactured Atis and some Creative ones usually employ[ed] better components with stricter tolerances, so they were claimed for their beautiful images; Matroxes were [and often are] the reference for monitor tests.
    Dvi signals should be unaffected by this filter, so their quality is (unfortunately) unimportant for today's card.
    OTOH, the vga cable may be unshielded and without ferrite rings, so they catch almost any interference: this was common with 12 and 14", because they had a low resolution, but is almost unique nowadays, since even low-class monitors are shipped with a decent cable.
    Zandrax
    Have an happy life.
    • weirdlookinguy
      • Sep 2007
      • 1638
      Re: HP w1907
      Nope, what I meant is that the card (ATI 9600, Manuf. by Powercolor and loaded with craptastic Evercon caps) has VGA and DVI outputs. When the LG was hooked up via VGA straight to the card's VGA output, the contrast was terrible. Everything looked overly bright and washed out. When I hooked up the LG via VGA, but this time to the card's DVI output through a DVI-VGA converter, it looked much much better. The fault was the card's VGA output, not the monitor. Anyway, I just got a DVI cable and all I can say is WOW. The difference is night and day. VGA looked kinda blurry, there was a little ghosting, and the picture was good but not all that great. With DVI.... wow.... a whole other story. The sharpness is spot-on, everything looks a lot clearer, and the colors seem a little more vivid. I am 100% satisfied with this monitor now. I would have been happy with either the HP or this LG, but I'm glad I went with the LG. Here's a pic (sorry about the messy desk, I really need to dust it). Any thoughts on this monitor?
      Also, what track record does LG has in terms of reliability of their LCD's? Does this monitor use an LG.Philips panel, and what kind of caps does LG use? If you guys can answer any of those questions or tell me your thoughts on it, I'd really appreciate it.
      • shadow
        • Feb 2007
        • 732
        Re: HP w1907
        This monitor uses an LG.Phillips panel. Or used to at least. I guess they could have moved onto cheaper manufacturers like my Samsung monitor. It does not use a Samsung panel even thou the same model used to!
        However I have no idea about the capacitors.
        • weirdlookinguy
          • Sep 2007
          • 1638
          Re: HP w1907
          I read about that, how some people got a Chunghwa panel instead of an actual Samsung panel. This monitor was made in China, even though the one on display at Fry's was made in Korea I guess they shifted manufacturing of this model over there, hopefully they stuck with an LG.Philips panel. The manufacture date is December 2007, and the FCC ID starts with BEJ, so we know for sure it was made by LG. Too bad this isn't a very popular model, otherwise someone would have figured out how to tell what panel you have without having to crack it open by now.
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: HP w1907
            Oh, BTW, I got the L196WTQ-BF.
            • shadow
              • Feb 2007
              • 732
              Re: HP w1907
              That's the only L196WTQ that's on the Australian website.
                by momaka
                03-15-2023, 10:17 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
                Wise Wing F199 19'' LCD monitor - recapped
                by momaka
                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                When I saw the Craigslist post, I wasn't...
                08-24-2020, 10:58 AM
