HP L2025 vertical lines
+ More Options
Posts
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Hi guys,
    I was just given this monitor for free. It kind of works but there are two vertical lines across the screen. My guess is that there's something wrong with the panel. I tried wiggling the cables and the lines stayed put. Everything else appears to be okay. Is there any way of repairing this or is the screen beyond hope? I really like the way it's built, very heavy and sturdy and nice picture quality. It even has S-Video and composite inputs which would come in handy for emulation so I'd be sorry to see it go. Also 4:3 screens bigger than 19" are getting hard to find and this one can do 1600x1200.
    Cheers
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Re: HP L2025 vertical lines
    Well, I'd just like to figure out what to do with this monitor. Scrap it for parts?
    • Half-Saint
      • Jan 2010
      • 213
      • Slovenia
      Just finished inspecting the inverter board and found that both 470uF 25V caps were replaced once in the past. The person who did it just snipped off the old caps and soldered the new caps onto the legs of the old caps. One of the cap legs was basically in the air so I cleaned the holes and properly resoldered both caps.
      Unfortunately this didn't fix the lines on the screen. I still suspect that there's a fault in the LCD panel..
      • samsonite
        • Jul 2015
        • 46
        I know nothing about fixing vertical lines, but a quick search on Google points to faulty ribbon cables or their connections. I would look at that after you have ruled out everything else: your computer, video cable (connecting monitor to computer), and computer's graphics card.
        btw, you should probably upload your images as attachments, instead of inline. It makes your post easier to read and faster to load. But, I find that users cannot edit their posts anymore after some time, so perhaps you are stuck with it.
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          I'll try to wiggle the cables around a bit and see, if anything changes. I know it's not my computer or the DVI cable I'm using. I did my share of googling as well and usually it's the panel at fault. The lines can be seen even on the OSD menu.
          EDIT: It's not the cables, that's for sure. Wiggling the cables does absolutely nothing
            That is bad LCD panel.
            Defective tab bond or bad drive IC.
            • Half-Saint
              • Jan 2010
              • 213
              • Slovenia
              So, if I understand this correctly, replacing the TCON board won't do a thing? You're speaking about the panel itself?
                That is correct. The T-CON is integrated into the panel so it is not replaceable any way.
                For examples:
                http://s807.photobucket.com/user/bud...ml?sort=3&o=24
                http://s807.photobucket.com/user/bud...ml?sort=3&o=33
                • Half-Saint
                  • Jan 2010
                  • 213
                  • Slovenia
                  OK, thanks! Case closed, as far as I'm concerned. I'll be salvaging the inverter board, power supply and logic board while the rest goes. Need space!
                  • Stanley1843
                    Screen Display Vertical Multicolor Lines
                    by Stanley1843
                    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                    06-29-2024, 11:54 AM
                  • gpo23
                    Sony KDL-40V3000 - Vertical lines
                    by gpo23
                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                    With the new t-con the color are good but there are vertical lines on all the screen :
                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                    Is there a way to fix the vertical lines on the new t-con ?
                    Thank you for your help
                    gpo23...
                    10-04-2023, 09:11 AM
                  • Firentiosi
                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                    by Firentiosi
                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                    The issues are as follows: the...
                    11-27-2024, 12:33 AM
                  • viking509
                    vizio e65 e3 LED tv color vertical lines center tv only
                    by viking509
                    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                    03-21-2023, 12:48 AM
                  • noisykid
                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                    by noisykid
                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                    12-30-2024, 07:15 PM
