Vertical line of stuck pixels on Dell U2410
  • LeChiffre
    • Jun 2015
    My trusty Dell U2410 recently developed a vertical line of stuck pixels on the left hand side of the screen (one pixel wide). Curiously the line does not go all the way to the top, but stops about 3 inches from the top.
    The line is blue but turns red on a black background:
    White background:
    http://i998.photobucket.com/albums/a...ps5qv90alf.jpg
    Black background:
    http://i998.photobucket.com/albums/a...psrpqpsbk2.jpg
    Blue background:
    http://i998.photobucket.com/albums/a...psleybwiit.jpg
    What I've tried so far:
    - Turned on the display while not hooked up to computer. Line shows up on black background.
    - Stuck Pixel software. I've tried many different programs each running for hours at a time. No difference.
    - Applied pressure and heat to the area with stuck pixels. No difference.
    - Taken the display apart and cleaned and reseated all ribbon connectors. No difference. Although I did manage to mess this up once which resulted in the entire left side being green and fuzzy. The line was still there.
    - Taken out the T-Con board and gave it a clean. No difference.
    - Turned the display on while the gold tabs were showing. Applied pressure to each one. No difference.
    So I'm at a bit of a loss. I've found a T-Con board on ebay I could buy for pretty cheap and try that, but I don't even know if that's the problem or the panel is just busted.
    Any help would be appreciated. I'm a complete amateur and my expertise consists of Google search I'm afraid.
  • mindoverflow
    ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
    by mindoverflow
    hello,
    there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
    I changed pads and thermal paste.
    I run mats test but it is reporting 0 errors.
    I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
    After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
    02-09-2022, 03:22 PM
  • otaku_nut
    Vizio E701i-A3 fixed but now has red vertical line
    by otaku_nut
    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
    08-19-2025, 06:11 PM
  • TrueSword88
    Kogan - KALED65XU9220STB - Blue Vertical Line
    by TrueSword88
    Hi all.
    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
    The line just happens to coincide with the end of COF and start of the next COF (attached).
    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
    Hoping to fix...
    05-05-2023, 04:28 PM
  • almarhum
    To fix laptop screen vertical line by working on its EDP cable
    by almarhum
    Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
    As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
    05-07-2024, 02:12 PM
  • mrsith
    Samsung UE58TU7100K - no picture, vertical line
    by mrsith
    Hi.
    Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
    This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
    Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
    02-07-2023, 11:18 AM
