HP 2311F Monitor: Flashing on & off
+ More Options
Posts
  • gagaguu
    • May 2015
    • 20
    • singapore
    My HP 2311F monitor is having an issue, turning on and off, after a while. After searching through this forum, I found similar thread (#56) posted by "matt230" on May 2nd 2013. It was suspected bad caps.
    Referring to "Bud Martin's guide", I was unable to figure out which caps are not working. The caps look fine by visual (neither bulging nor leaking) but I do not own the capacitance or ESR meter. It would be grateful to have some suggestions which caps might fail.
    Followings are the info that I'm able to dig from the monitor:
    PSU board: Lelon caps (www.lelon.com.tw)
    1) 470uF 25V
    2) 330uF 25V
    3) 33uF 160V
    4) 330uF 16V
    Logic board: Su'scon caps (www.su-scon.com)
    1) 3 x 100uF 16V
    2) 8x 10uF 16V
    3) 1 x 2.2uF 50V
    Display by LG (LM230WF5)
    and the photos which might be useful
    Thanks, in advance, for your time.
    Regards,
    Win K. Soe
  • 1supertech
    • Apr 2012
    • 384
    Re: HP 2311F Monitor: Flashing on & off
    Check your power supply make sure your getting 12volts. Replace all the caps
    • gagaguu
      • May 2015
      • 20
      • singapore
      i've checked the supply. the display acts normal in the first two or three minutes. i starts turning on and off after that.
      • Porto
        • May 2015
        • 109
        • NL
        something is getting too hot after two minutes and shuts down, than cools off and restarts etc etc.
        Monitor the temperature of the mosfet, I can't read what's written on it but it's that 3 legged thing in the middle of the powerboard.
        Also that eight legged IC left of it, I guess that's the driver.
        The caps are suspicious also. If they are not bulged or leaking, check the ESR if you are able to.
        Bad/cold solder joints?
        • gagaguu
          • May 2015
          • 20
          • singapore
          Hi Porto,
          the mosfet (Q855) is B70N08 and IC (I801) is FP6180 from feeling technology.
          data sheets are attached.
          i'll check the caps solder joints thoroughly again.
          thanks for your time and advice.
          rgds.
          • Porto
            • May 2015
            • 109
            • NL
            Then I guess the Fp6180 IC is not the driver for the mosfet.
            I had an Acer monitor which had the same problem, worked for a few minutes and then it began to reset again and again...
            I wanted to replace the mosfet because I thought that thing was getting too hot because of internal issues; maybe it was already dying on me. Unfortunately, I didn't get the change because I blew not only the mosfet but a few other components also when trying to measure the Gate pin, slipped with the probe, ended up in between the gate and the drain pin, some fireworks and am still waiting for the postman to deliver new components to me!
            So, in short, try to desolder that mosfet and (temporary) install a similar other one. If you can't get hold of a SMD mosfet, just try to attach a through hole one just for testing, if the monitor works you know what to order (or leave the through hole if it fits nice).
            E.g. an (ST)P50NF60 will do just fine and is quite common, I always use them to test a suspicious mosfet. Pin 1,2 and 3 are similar --> Gate, Drain, Source.
            • gagaguu
              • May 2015
              • 20
              • singapore
              Hi Porto,
              noted. will follow up after i come back. so far, stuck in indonesia for a while..
              don't wish to have firework though...
              thanks for the advise...
              rgds.
                Try lowing the backlights down to about 50% to see if it will stay on longer.
                • gagaguu
                  • May 2015
                  • 20
                  • singapore
                  Hi Budm & Porto,
                  Appreciate the advices...I'm back at home today and will continue finding the fault...My friends discourage me about trying to get it right..but they don't know that it's not about $$$ but the knowledge, the satisfaction and, ofcourse not omitting, the personal achievement. Again, thank you so much for the advices and your time. I will keep you posted...
                  Rgds,
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    It looks like this monitor uses an external power supply? Have you checked that for bad capacitors?
                    -David VanHorn
                    • gagaguu
                      • May 2015
                      • 20
                      • singapore
                      Budm,
                      lowering the backlights doesn't change....solder joints are good enough...is it possible that 6180 converter is dying?...i mean thermal shutdown function in works? coz it's normal in the first 2 or 3 minutes and then blinking starts..."porto" recommend replacing the mosfet...should I start with Lelon caps first?
                      Agent24,
                      yes..ext PS...but i may never know bad caps cos i don't have ESR meter (n referring to "budm", checking with capacitance meter is not 100% reliable)...
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4951
                        • New Zealand
                        Originally posted by gagaguu
                        Agent24,
                        You did not show a photo of the inside of the external PSU so I thought perhaps you had not done even a visual inspection of the capacitors there.
                        -David VanHorn
                        • gagaguu
                          • May 2015
                          • 20
                          • singapore
                          Agent24,
                          Thanks for the advice...but ext psu is supplying 12V it's supposed to...and the monitor is acting normal in first two to three minutes...
                          rgds,
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4951
                            • New Zealand
                            Got any freezer spray? That could help narrow it down.
                            I just remembered a monitor I had which had a similar problem. Would start up, work OK for a while, but after the microcontroller IC heated up, it went nuts. I found that if I cooled that IC it would start working again.
                            -David VanHorn
                            • gagaguu
                              • May 2015
                              • 20
                              • singapore
                              Negative...i could try thin Al heatsink with Cooler Master paste...but IC packaging would not affect that much on heat transfer rate...any advice?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4951
                                • New Zealand
                                Get some freezer spray, or a can of compressed air that can be turned upside down and used as one.
                                Or try the ideas the others suggested first.
                                -David VanHorn
                                • gagaguu
                                  • May 2015
                                  • 20
                                  • singapore
                                  thanks...ribbon cable was gone from wear & tear...will update..
                                  • gagaguu
                                    • May 2015
                                    • 20
                                    • singapore
                                    Re: HP 2311F Monitor: Flashing on & off : Culprit found but need some advices
                                    I am trying to figure out what's causing my HP 2311F display flicker.
                                    I got really helpful suggestions and advices...
                                    i was following 'BudM's sticky' and it is really an eye opener...
                                    (thank you so much.)
                                    in a nutshell, my monitor was having a LDO regulator, U1 on Logic board, faulty.
                                    For those having same problem as me, you would have a rough idea...
                                    Please refer to the attached datasheet.
                                    (it was thermal shutdown function in action.)
                                    That being said,, what would be the compatible regulator?
                                    Pls help.
                                    regards,
                                    Win K. Soe
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4951
                                      • New Zealand
                                      There are probably several regulators which would do the job.
                                      Go to Digikey\Mouser\Farnell etc and search for one that meets the same specifications.
                                      You need same package type (well, you can get creative but it's easier if you have the same package)
                                      Same output voltage, same output current (1.2A) etc.
                                      Same or lower dropout voltage (NOTE: it's different for different output voltages)
                                      Also, are you sure the regulator is bad, and there's no short on the output?
                                      -David VanHorn
                                      • gagaguu
                                        • May 2015
                                        • 20
                                        • singapore
                                        I borrowed an IR thermometer and checked every converters, regulators, etc...
                                        it checked out this regulator. It's temp is higher than others.
                                        (but the temp is within it's op temp and i dont understand why)
                                        So i tried the dummy test. put a little thermal paste and Al heatsink.
                                        I tested it the day before yesterday for 4 hours plus. ok..
                                        In fact, i m testing it with that heatsink now..it's over 3 hrs and no flicker...
                                        (during this 3 hrs, i took out the heatsink and it flickers, putting it back, ok..)
                                        so I'm 85% sure that regulator is causing the flicker.
                                        From datasheet, it's AX6630A 3.3V.
                                        I will check with RS Singapore.
                                        thank you so much Agent24.
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                          Westinghouse L2210NW LCD monitor - bad caps repair
                                          by momaka
                                          Here's another LCD monitor repair: Westinghouse L2210NW.
                                          Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                          I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                          Pictures of the monitor outside/case after a brief...
                                          01-11-2021, 01:14 AM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
