Dell E196FPf - No image or power indication
  • JimsMonitors
    • Aug 2013
    • 7
    Good Day!
    I have a Dell E196FPf LCD Monitor that when I turn on gives no image and no power indication on the LED. So I opened it up to check out the power board (suspecting to find a few bad caps). Everything looked just fine (no swollen caps, no dark areas, etc.). The power supply board number is: 79044120-R (490441200113R on back side of board).
    Based on what I read on another post, I tested the voltage across the large capacitor. It read 165.8V steady. I also tested the voltage levels on Pins 3 and 7 of U850 (power controller). Pin 3 was 18.18V steady and Pin 7 was 15.52V steady.
    Based on this information, can anyone offer me any suggestions as to what I should try next?
    Thank you.
    Jim
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Dell E196FPf - No image or power indication
    Try bypassing the power switch entirely. That's one thing to try. Also, do you have an ESR meter?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      What do you mean by bypassing the power switch?
      @JimsMonitors: How about some clear pictures of the unit and boards?
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Fully removing it from the circuit and when plugged in to mains, touching both wires together to simulate the pressing of the power button.
        sigpic
        • andrhouseolly
          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
          by andrhouseolly
          Hi.
          I kindly ask you to help me solve the problem.
          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
          The board turns on, there is no image.
          Read more. When the power supply is connected, the front panel indicators light up briefly.
          When you press the power button, the button indicator lights up. The board works
          there is no image, there is no matrix initialization, there is no image on HDMI.
          When turned on, the fans do not spin, but when they warm up they start spinning.
          When you turn off the button, the fans spin up to full speed for a short...
          05-11-2024, 03:14 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • huzo
          Dell 5590 no image on LCD,HDMI works ,the board works...
          by huzo
          The board is LA-F411P ,DELL 5590 ...
          The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
          02-16-2025, 03:08 PM
        • juergenb
          Dell Precision 3660 - BIOS Image, Hidden Settings, Thermal Settings ?
          by juergenb
          I got my self a new Dell Workstation (Dell Precision 3660, i5-13500).
          Unfortunately, Dell has fixed the front fan“s settings in the BIOS.
          Both the speed and the presence of the fan are fixed.
          There seems to be no hidden setting.
          The thermal tables for the speeds were changed in one of the last BIOS updates.
          Do you see a possibility to change these tables from the BIOS update file?
          Precision_3660_2.1.0 -> Release Notes
          Updated the thermal table to reduce fan noise.
          Updated Intel Management...
          08-12-2023, 03:50 AM
        • AnguiXD
          Dell G3 3579 no image
          by AnguiXD
          I have a dell g3 mb la-f611p and it has no image
          Already tried the external screen but the result is the same
          Bios was corrupted because it wasn't even powering on, after flashing it started booting
          It seems to work, it responds to cntr alt del command and caps/NumLock.
          Appreciate some help with it!
          05-12-2025, 04:18 PM
