Asus VW22* monitor
  • charger440
    • Mar 2015
    • 7
    • usa
    Asus VW22* monitor
    Hey guys
    I have two of these monitors that come on then turn off within a couple seconds. However, if I disconnect the video (?) Ribbon cable and turn the monitors on they will turn on the back lights like they should and after a few seconds the amber light will come on indicating standby mode.
    Any advice for me or do you need more details? Just let me know.
    Jim
    Re: Asus VW22* monitor
    Pictures of the back side of the monitor that shows all the boards?
    Are you talking about the cable between the LOGIC/Main board and the LCD panel assembly?
    • charger440
      • Mar 2015
      • 7
      • usa
      Yes, that's the cable I am referring to. I can get you pictures of the boards tomorrow if you like.
      Thank you for responding.
      Jim
      • midibob
        • Nov 2008
        • 285
        This sounds similar to the fault I have on my ASUS which I started a thread recently.
        Does it display 'No Signal' before it goes into standby?
        Midibob
          Originally posted by charger440
          Hey guys
          Jim
          So if the ribbon cable to the LCD panel is bot connected Dnd if you have MONITOR connected to running PC, the backlights will stay on and it does not go into STBY, right? If that is the case, to me you have something wrong on the T-CON board on the LCD panel assembly.
          • charger440
            • Mar 2015
            • 7
            • usa
            Midibob
            The only way it will stay on is disconnect the video ribbon cable from the panel so there is no display when it's on. If I connect the cable to the panel it comes on once then goes off immediately and subsequent presses of the power button does nothing noticeable.
            • charger440
              • Mar 2015
              • 7
              • usa
              Let me try that and I will get back to you.....
              • charger440
                • Mar 2015
                • 7
                • usa
                I plugged it into a computer and as you can see, it is on. I guess it looks like a bad t-con?
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Yes issue with tcon
                  • charger440
                    • Mar 2015
                    • 7
                    • usa
                    Thank you all for the help!
                    • midibob
                      • Nov 2008
                      • 285
                      That's interesting, I hadn't tried running mine without the ribbon connected. Will try that later and see what results I get.
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
                      • sew333
                        Pc shutdown, monitor flickered with no signal after 10 seconds
                        by sew333
                        My pc:
                        10850K stock 4800mhz stock Kraken X73 good temps
                        2x16 GB DDR4 GSKILL 3000mhz XMP
                        Seasonic Tx-850 Ultra Titanium
                        Gigabyte Rtx 3090 Gaming OC
                        Aorus Z490 Pro Gaming
                        1 TB SSD
                        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                        Power...
                        02-22-2022, 10:27 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • keepread
                        Dell monitor PSU vs Dell laptop PSU
                        by keepread
                        Hi there!
                        Someone gave me their old monitor, it's Dell S2715ht.
                        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                        10-30-2025, 04:45 PM
                        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                        09-07-2024, 02:50 AM
