CapXon replacement for I-Inc iU191D 19-inch TFT LCD Monitor
  • drex79
    • Mar 2015
    • 5
    I found a (seemingly) brand new I-Inc iU191D 19-inch TFT LCD Monitor sitting in a pile of garbage. I brought it home, cracked it open only to find all CapXon capacitors, half bulging and 2 leaking.
    I have replaced caps before but only the 'kits' for known monitors. Unfortunately, I haven't managed to locate any for this particular model, however it seems that the power board is used by other companies.
    Here is the list of caps I de-soldered from the powerboard. All pulled from model FSP043-1PI01, P/N 3BS0123213GP REV1 ;
    Code:
    Brand		Model		Capacitance	Voltage 	Width		Height	Board Location
    CapXon		C638		470uf		25V		10mm		15mm	C261
    CapXon		C636		470uf		10V		8mm		12mm	C242
    CapXon		C638		1000uf		10V		10mm		16mm	C241
    CapXon		C638		1000uf		10V		10mm		16mm	C244
    CapXon		C638		470uf		16V		8mm		16mm	C503
    CapXon		C638		470uf		16V		8mm		16mm	U501
    CapXon		C638		470uf		16V		8mm		16mm	C501
    CapXon		C638		470uf		16V		8mm		16mm	C502
    CapXon		C638		2.2uf		50V		5mm		11mm	C232
    CapXon		C636		22uf		50V		6mm		11mm	C123
    CapXon		C638		470uf		25V		10mm		15mm	C24
    I was looking for a list of replacements, I found Panasonic FC Series.
    Will these be a suitable substitutions for the horrible CapXons?
    Any input would be appreciated.
  • drex79
    • Mar 2015
    • 5
    Re: CapXon replacement for I-Inc iU191D 19-inch TFT LCD Monitor
    Bump.
    More specifically, would these be good candidates for replacements;
    Code:
    Manufacturer Part Number	Manufacturer	Description				Capacitance	Tolerance	Voltage Rating	Ripple Current	Impedance
    EEU-FC1A102			Panasonic	CAP ALUM 1000UF 10V 20% RADIAL		1000uF		±20%		10V		787.5mA	68 mOhm
    EEU-FC1H2R2			Panasonic	CAP ALUM 2.2UF 50V 20% RADIAL		2.2uF		±20%		50V		29.25mA	1.8 Ohm
    EEU-FC1H220			Panasonic	CAP ALUM 22UF 50V 20% RADIAL		22uF		±20%		50V		100.8mA	1.3 Ohm
    EEU-FC1A471			Panasonic	CAP ALUM 470UF 10V 20% RADIAL		470uF		±20%		10V		416.2mA	117 mOhm
    EEU-FC1C471L			Panasonic	CAP ALUM 470UF 16V 20% RADIAL		470uF		±20%		16V		547.5mA	85 mOhm
    EEU-FC1E471L			Panasonic	CAP ALUM 470UF 25V 20% RADIAL		470uF		±20%		25V		746.2mA	65 mOhm
    Thanks.
      I use FM/FC/FR for all my repair so as long as the diameter and the height will fit then they are OK, FM is the improved version that came out after the FC, and now they have FR series.
      https://www.badcaps.net/forum/showpo...2&postcount=65
